EmmitJSwan
- Jul 8, 2024
What is the diode mod? I've seen it mentioned in a few posts, but haven't found any write ups. I noticed some audi and vw also mention a diode mod. Anyone have any experience with it? What’s the point? Thanks!
Sounded janky to meIt is incredibly outdated and bad advice with the intent to clip the voltage coming from the MAF to get around LH2.4 fuel cut.
What ends up happening is you lean out the motor as the RPMs climb instead of cutting fuel. Please do not do it.
Especially when peak power is at like 5kOn a side note, I might just be old or overly practical, but it bothers me when some users are looking for ways to get around the factory rev limiter when in 98% of cases you're already well on the downside of the power curve at that point and should have shifted 200 rpm ago.
Stock B230FT makes peak power at 4800 iircThat is a broad stroke to paint the redblock with.
Which stock cams are you referring to?With the stock cams there isn't much happening above 5k rpms.
M, T, specifically. A and B are better but still aren't a high output cam. V gets you closer with K, and H pretty hot from Volvo. I've been spoiled with the all around goodness of Enem V15 both n/a and T versions are great street cams.Which stock cams are you referring to?
