DIY EFI Core4 Volvo ECU (Is it worth it?)
Alois Carles
I found a ecu that is PnP to 1991 Volvo 740 Turbo and can be tuned with my laptop and add things such as wideband sensors. Also another strong point is the fact it has a MAF delete which is great but I wanna know what are the genuine downsides vs a mainstream Standalone ECU. I think it sounds to good to be true.
My goal with my car is a full drift build which I know a lot of people will say genuine standalone is better but I am not sure especially when you pay about 1k USD for a ECU that has wideband sensor included, and 34 pin aux connector.
Sounds like you're already over your head. Have you drifted this car yet or just lofty IG goals?
Yes i have drifted before as well as well as im already doing work on the car, the car is currently with IPD turbo cam, BC coils, 90 Ah Poly bushings on every suspension bit, IPD sway bars. My ECU in the car is currently giving out as it no longer recognizes the temp sensor as well as has overfueling issues linked from boost. So instead of getting a stock ECU might as well get a tunable ECU. or Standalone
If it's not obvious, that's a Speeduino ECU with Plug-and-Play adapter boards for LH2.4/EZK.
First off, do you have a CAT and any emissions requirements in your area? Meeting emissions, especially NOx, with most aftermarket ECUs can be difficult.
The advantage of a Plug-and-Play setup is that it reuses the existing wiring and connectors. The disadvantage is that it won't fix old decaying wiring, damaged connectors, or bad sensors. If your current ECU is having problems, you may end up with a crank-no-start after swapping to an aftermarket ECU. I'd try to fix any known issues before swapping.
Without rewiring the injectors and ignition coil, you'll be running batch injection (all 4 injectors pulsed at the same time, once per engine cycle) and single coil distributor ignition. With rewiring, you can change to distributorless wasted spark ignition, and semi-sequential injection.
Is there a dyno tuner in your area that will take on a running&driving Speeduino tune? The fueling table you can do yourself, but getting the best performance out of the spark table takes a dyno and some experience.
LH2.4/EZK do pretty well for slightly bigger turbos and slightly higher boost. Aftermarket is nice for more major upgrades. What are you longer term boost / HP goals? What fuel? Is this a DD or are you OK if it breaks for a month?
first off thanks for the reply, and im in the US and there are techniclly emissions rules but i dont follow any and I dont have cats or EPF :ROFLMAO:
My current ECU is having internal issues as the actual signal is being read as well as sent to the ECU but the ECU does not recognize it which I read was a issue on these cars.
I do plan on doing distributorless spark ignition in the future but at the moment will stay with it.
As for the tuning i will bring it to a shop to get it dialed in as i said before obviously im not a good tuner or at all actually but am willing to learn. I will do some calling around for that.
I plan on pushing 250-300 whp end goal later on with bigger turbo and built motor with CD009 trans. And I want it semi reliable to be a DD but ok if its broken ever now again as i have a second car anyway
For the MicroSquirt, if you add in the cost of tuning software ($100 for the non-lite versions) and an external MAP sensor, it's about $645, and the newer/more feature rich MS3pro Mini is only $30 more.
Here's my latest comparison chart for the various entry level MegaSquirt and MaxxECU boxes. It's not all apples-to-apples, but pretty close. For any of them, you'll need to map out exactly what you need for I/O pins and features. The MaxxECU Mini is tight on I/O pins (unless you add some over CANbus).
bobxyz has a point:
1) If you do a P&P install into a car that does not have a good stage 0 (everything works well) - you are very likely to get some issues with that too. Often there are bad wiring in the old Volvos, bad sensors as he says etc.
2) If you cant tune it or know about sensors, triggers, hall vs vr, missing tooth, wasted spark etc. you have a lot to learn up on.
3) even with a cheap ECU, most likely you will use a lot of money for the conversion. You should really upgrade the fuel pump cabling and dedicated relays for it, maybe you have to upgrade your ignition, sensors for afermarket EFI etc. its easy to use A LOT on this :P So if your car is not very good/nice, little rust etc. I would personally rather swap the car.. If you have a very rare car, like an 164 or a 242 or 780, 262 etc. then of course I can kindof understand spending a lot of silly money. But lets say you have a very normal 244 with rust, dents etc. then I say: sell it and buy an lh2.4 240/24(5) with good chassis etc. then you can +t it quite cheap on lh2.4.
Now I dont want to be a negative person, but I have seen a lot of people doing upgrades in bad project cars.
They spend A LOT on it, then they end up selling the car for parts.
So keep in mind: if you are not VERY happy with the car it self, I would just sell it, buy a better one to mod (or keep as is).
