drunkmonkey
DrunkMonkeyCustoms.com - 3D Design & Manufacturing
- Jun 1, 2020
- Sacramento
Current:
Parts List:
stock '94 B230FD with stock ft 530 head
Elring head gasket
Microsquirt
Blue 350cc Injectors (for now)
3 bar FPR
AEM 340LPH
V6 Mustang WC T5 with BNE adapter plate
Coleman single piece driveshaft
Stepped Flywheel with turbo pressure plate
Spec Stage 2+ 9" clutch
Mcleod adjustable throwout bearing
90+ Manifold ported for T3
Hard Race Inconel turbo studs
Holset HX35W 10cm with billet compressor wheel
Yoshifab Breather plate
Benzforce -12 extended oil drain flange
Hello All!
Let me introduce you to my '88 245 DL.
Its a Polar White manual M47 with blue interior.
Bought 12/20/2020 for $600. The previous owner bought it from an auction with plans to make it a street car but lost interest.
Went to just look but ended up buying it and had it driven to my house. Odometer broke at 350k so I'm sure it has 400k plus.
First issues I noticed was the coolant temp reading higher than usual. I bypassed the Temp board and that fixed that issue.
Day 1:
I planned on drifting this car so installed a spartan locker and did a stage 0 tune up.
Instead of polishing the lights, I wrapped them(ew I know).
After Paint Correction, Cut Springs, and SN95 wheels
850 lip makes a big difference
Eventually did the EZK 116 conversion to get rid of the Chrysler ignition and to get ready to +t it.
Drove it for a while and then decided to go Microsquirt for engine management. After a lot of research and wiring, I had the car running on my own N/A tune.
Swapped in a A Cam and an adjustable cam gear with the timing advanced, which made a big difference. Converted to a single AEM 340 in tank pump and ran -6AN line from the sending unit to stock fuel filter and swapped in a 3 bar FPR.
Fast forward to 9/2023, I noticed my oil pressure light intermittently coming on when cruising and decided park it for the meantime.
Found a low mile B230FD Squirter from a '94 940 a while back that I decided to freshen up.
Since the B230FD is an EGR motor, I decided to swap a low mile turbo head that I had cleaned and skimmed instead of plugging the pulse air ports.
Will add more later....
Parts List:
Elring head gasket
Microsquirt
3 bar FPR
AEM 340LPH
Hello All!
Day 1:
