R32RennSport
Outlaw Amazonian
- Nov 20, 2011
- Atascadero, CA
Looking for confirmation and a little advice. I'm swapping over my 1966 122's original open system radiator to a later closed style radiator. To start I already knew I would have to choose between modifying the radiator mounting brackets on the new radiator or cutting off the mounts at the core support. I decided to cut off the mount at the core support.
The problem I'm running into though is the outlet at the top of the radiator is 3/4 inch lower center to center compared to the original when fully seated in the core support tab. Luckily the dowel is quite a bit longer on the base on the new radiator so I was able to space it up 1/2 inch (without creating an air gap) but it still leaves the outlet sitting lower than I need. This normally wouldn't be an issue but the plastic 5 blade factory fan is a few 32nds from contact the hose which doesn't make me feel too warm and fuzzy.
My options are this. My thinking is I can attempt to lower the engine slightly by slotting the engine mount brackets at the block or what I'd prefer to do is trim the plastic fan blades down (they are already longer than the original 4 blade anyhow).
Thoughts? Advice? Has anyone ran into this issue before?
