I have this in my 244. It did not like the me7 intake manifold very much, at least not in my case. It runs excellent with the one I modified. You would have a hard time getting a stand alone ecu to run as good as this. Vast deleted most of the non essential sensors, but I had to leave the charcoal canister/evap valve attached. From memory: crankshaft, camshaft, knock (2), coolant temp, maf, boost control (tcv), evap valve, speed signal from instrument cluster and front oxygen sensor. It can use a wideband sensor if you want. You can ditch the single coil setup for a coil on plug set too.
Pro's
Much cheaper than a standalone
Proven reliability
Oem-like drivability
Very good stock knock control
Good boost control
Two maps that can be switched while driving
Con's
Wiring is harder than a standalone (in my opinion). Costs more time to go through everything.
Limited to one tuner (Vast)
You have to spent time doing 3rd of 4th gear pulls to redline multiple times until it is dialled in.
No other programmable safety's like boostcut when running lean (it does retard timing), low oil pressure engine shut off, etc
VVT control is very limited (if your engine has vvt)
Limited OBD capabilities
I think it starts to have it's limitations if you're aiming for 400hp+ (controlling big turbo's / injectors)
No flex e85 control
