mopar318
- Apr 8, 2013
- Fort Wayne
Seems pretty silly to be talking about $2,000+ ECU's and not even using DBW.
I’m not opposed to it but it’s not a deciding factorSeems pretty silly to be talking about $2,000+ ECU's and not even using DBW.
Have you looked at fuel tech at all? Under $1000 with a harness if you don't need a lot of inputs/outputs.I’m not opposed to it but it’s not a deciding factor
It took me like 2 hours to make a basemap on my ECUmaster. You can literally download one for any other ECU and copy the numbers over manually. Trigger offset and stuff is something you ALWAYS need to double check and adjust, basemap or not. Maybe 5 hours to build a harness for my ECUmaster. To me that made it not worth buying a pre-made harness that won't be an exact fit for my car and the additional sensors and stuff I want to set up.No comment on capability / price of EMU Black vs. MaxxECU.
To me, one of most compelling reasons to use MaxxECU is they sell a pre-terminated wiring harness for the B5234T engines, and have a base map available to download. Those two items significantly cut down the amount of time and number of potential errors in getting a standalone ECU fired up and driving.
I looked quickly and wasn't able to see if ECUMaster's available base maps include a B5234T. ECUMaster doesn't sell a premade harness, just a flying lead harness. Some extra time/work but you definitely save money compared to buying a MaxxECU finished harness.
What is ecu did you go withIt took me like 2 hours to make a basemap on my ECUmaster. You can literally download one for any other ECU and copy the numbers over manually. Trigger offset and stuff is something you ALWAYS need to double check and adjust, basemap or not. Maybe 5 hours to build a harness for my ECUmaster. To me that made it not worth buying a pre-made harness that won't be an exact fit for my car and the additional sensors and stuff I want to set up.
Not yetHave you looked at fuel tech at all? Under $1000 with a harness if you don't need a lot of inputs/outputs.
That’s good to knowI know this wasn't directed at me but I need to let you know...
I literally just returned from speaking with an installer. Someone that I would consider to be an expert at his craft. He informed me that the EcuMasters EMU Pro and the EcuMasters Black use different connector types. I haven't confirmed this but wanted to let you know that if the Amp Superseal (Emu Pro) connector is important to you, check this before proceeding.
Personally, I think that the Emu Pro would be like using a shotgun to kill a cockroach for your use case
ecumasterusa.com
That’s good to know
I was considering using this bot the pro
ECUMASTER EMU BLACK
ECUMASTER EMU BLACK is a universal engine control computer that manages the operation of spark-ignition engines, and is designed to work with the most advanced and complex currently available engines. It is the successor to our proven system, the ECUMaster EMU. Common applications for the EMU...ecumasterusa.com
