164volvo244
- Jun 1, 2023
Hello,
First of all, if my english is bad, i never thought i needed english when i was in school
first the project.
The original engine (b21a) is to be swapped for a volvo B230FK from an 940. It's a '93 engine so it's had oilsquirters.
things i've already done:
- engineblock resurfaced
- new conrods (BSR H-profile)
- forged piston's (suplied by the company who did the resurfacing) 2nd oversize to be sure its al perfectly round etc.
- mulitilayer head gasket (must be ok to at least 300 HP
- new heavy valvesprings
- ARP headstuds
- 3 inch stainless steel exhaust ( not fitted, i have to weld on a bush for the O2 sensor)
And the rest is just what anyone would do when rebuilding an engine (gaskets and such)
To be able to put it in an 2 series volvo i have fitted an volvo 2 series LH 2.4 wiring harnass on the engine,
let out the resistor pack an fitted 0 280 155 830 Bosch injectors (350cc) resistance 12 Ohm
Put it on a test stand and let the engine run.
And it runs. sort of...
things i still need to do
- didn't chip the ecu yet so it doesn't have the correct mapping for the 350cc injectors (i assume)
- haven't figured out if i will keep the stock 13c turbo or change it for an 15g, or go a bit further and fit a 16t turbo
- still have the stock AMM i believe its a 016. Keep or change to 960 AMM
- increase boost (to wich level i don't now yet
- ECU is 0 0280 000 561 white lable EZK 0 227 400 176, are they good or do i need a diffrent one
- change camshaft to a different profile? still have the stock one (don't know wich one it is)
i will look for it when i retighten the headbolts. but it has to be warmed up first
- i have 4 968 green bosch injectors laying around for some reason
what do i have to do to fit these in my engine
as for the moment the engine runs, and as i mentioned before 'sort of'
It has an extreme rough idle en when opening the trothle it wil misfire. (way to rich)
so my question is what is best.
just get a chip en run stock with increased boost. Or go further and fit a different turbocharger, AMM, 968 injectors, get the right chip and a fasten your seatbelts where about to fly warning light.
is there anyone that could help me with these questions.
greetings Erik
first the project.
- ARP headstuds
greetings Erik
