Well, i did the Sacer-fix on the magneti-Marelli ETM (my ETM typenumber ends with 347 so it should work)
I swapped the original TPS with it's contact tracks for the SACER magnetic contactless TPS.
(Why Volvo/Magneti-Marelli didn't use this type of contactless TPS is beyond me! Contactless seesm like a no-brainer to me )
i used the exact instructions as described in the Sacer-pdf. (even though they do not seem to be very complete)
After the swap i did the VIDA-ETM-test. I did not see the throttle plate move/open/close... i suppose i should have seen that?
i was under the impression that i would see exactly the same TPS-logs on TPS1(Sacer) and on old TPS2...
But i only see 1 super strong stable TPS1 signal, TPS 2 is at 30% all the time. It does not vary at all.
i used this install method:
I was under the imprssion that this swap would get me 2 almost identical super stable TPS signals....
Did i miss something? Did i make an installation error?
I installed the ETM on the car and it did start up but the idle is still not very stable. And the car still produces CEL-errors...
Anybody have any suggestions?
