Found these the other day, along with the tie rod extenders.. it’s on my short list. Just hoping to find some reviews from folks who have used em.If you are going to be running a anti roll bar you will need to add a bracket for that
240 heavy duty extended lower wishbones - Classic Swede
240 heavy duty extended lower wishboneswww.classicswede.org
I've seen a complaint or two about the bushings, how have yours held up? I have a set on the shelf still have debated if I want to use them or not.I have them. They are nice. You need to figure out your own anti roll bar end link bracket solution.
They seem fine so far. Would definitely look at getting something substantial for the rear cup bushings, as the fronts will not locate the control arm along the pivoting axis of the arm. If you plan on drifting or rallying like Bobbert, plan on reinforcing them so they don’t fold in like a taco, at least according to him.I've seen a complaint or two about the bushings, how have yours held up? I have a set on the shelf still have debated if I want to use them or not.
I extended mine 2" with no problems. Check the build thread in my sig.I'm planning on lifting my 85 240 wagon about 2"-3" and I was wondering what would I need to bring the front alignment back within spec? I've heard I need to extend the front control arms but how would I go about doing that? Thank you.
The folded arm was due to me ditch hooking while drifting hard enough to pull the rear poly control arm bushing out of its sleeve. Can’t really fault the arms for thatThey seem fine so far. Would definitely look at getting something substantial for the rear cup bushings, as the fronts will not locate the control arm along the pivoting axis of the arm. If you plan on drifting or rallying like Bobbert, plan on reinforcing them so they don’t fold in like a taco, at least according to him.
Put a tab on the strut for more effective roll control.I have them. They are nice. You need to figure out your own anti roll bar end link bracket solution.
That’s what volvo did on the group A cars…Put a tab on the strut for more effective roll control.
I found these in my googling which look fairly well thought out:I've seen clamp-on ones for Porsche stuff too.
