Failz
- Jun 13, 2021
- Albany, NY.
I have a second brick now because the first one is substantially less dangerous as a lawn ornament behind my shed. Still runs, just tries to kill me when it does and is a rusty POS.
A 1991 240 with marginally less rust than my 93'. 240k miles as any good 240 should have. Generic NA auto. It's name is Goose. Obtained back in September. Lovingly abused and mistreated by the previous owner(s) as is the usual. Excellent interior other than a pretty well cracked dashboard. Trunk is also clean and mostly rust free.
THE PLAN:
I've already done 1 +t on the other shitbox and on that setup it was basically a straight factory turbo setup. Garret turbo, late style turbo manifold, OEM plumbing and intercooler, 954 ECU / 148 Ignition. Orange top injectors. World's jankiest m47 setup slapped on for flavor. I've learned a whole lot from that adventure, namely what stuff I probably shouldn't have bought (that being the 30+ year old turbo that smoked like a chimney until I got immense levels of PCV suck). Also, the fact that the OEM downpipe / exhaust hardware sucks. I hope to never see that giant downpipe and it's miserable donut ring catback connection ever again.
Going to keep it auto this time. This decision will probably bite me in the ass but I'm an expert at making poor decisions. Injectors / ECU / Exhaust manifold are going to be the same as last time, I think they're fine / imo the best fit for purpose. The big ticket change is i'm going to try running a cheapo MaxSpeedingRods t3/t4 t04e. Will it explode? Probably. Given i'm not going to be going nuts with it boost wise and the relatively decent reputation of MaxSpeedingRods (provided you keep your expectations in check) I don't think it'll be a huge deal. Also the idea of running a $130 dollar turbo for shits and giggles makes me grin. Worst case scenario I've yanked the engine in shitbox #1 so many times now that I'm not terribly concerned about doing it again. Snagged an OEM intercooler for cheap already.
The Stage Zero Zone:
I can tell somebody at some point cared about this car. Other than the localized rust, it's pretty clean. There's a mileage badge or two in the interior and some minor aftermarket stuff done under the hood. There was also some suspension work done in the rear end. Unfortunately, it's been a good minute since that person owned the car clearly. Last owner didn't really do anything worth noting as far as I can tell.
THE PLAN:
- Timing belt is starting to surface crack
- Oil hadn't been changed in a good while when I got it.
- Tires were/are bald. Swapped with the wheels off my other shitbrick.
- Water pump is leaking profusely. Not enough to be a hazard to drive but enough that there's a shiny bright puddle of green coolant on top of the pump and soaking everywhere. Actually it's kinda crazy how clean the coolant is compared to everything else. Waterpump bearings don't feel great when spun. Not terrible, but starting to go for sure.
- Front seals are currently very upset and leaking sludge all over. I haven't dug down to the crank yet but based on the sludge I can see crawling up the walls from down there, I fear for my safety.
- Based on the above and recommendations from others, PCV probably needs a cleaning. I can only see sludge when looking beneath the manifold.
- [Cosmetic]: Someone did the windshield poorly and there's the forbidden brown leaking from behind the gasket (but not into the car). That is a problem for when the warm weather comes out.
- I pressure washed the engine bay once already. I'll do that again later. Substantially cleaner.
- Someone at some point summoned infinite brainpower and swapped the 12v coil for a 6v one. I do not know how this system is functioning at all (it runs well regardless though).
- Gauge cluster temp faker died. Lamp cord trick to the rescue.
- Odometer wasn't working consistently, it's fixed now.
- Fuel relay died in a parking lot. Didn't realize it was that until I got it towed home. Replaced the dead fuel sender in the parking lot thinking it was that (cables rotted at the bulkhead). Yay new fuel sender?
- Original headunit was an early 2000's alpine one, gaudy as hell and didn't work at all. Replaced with a 740 unit that's been slapped in the aftermarket bezel. Barely fits but it's w/e. Tape deck worked, then ate a gear. I printed off a new gear. Worked great for 20 miles. Ate another gear. Waiting to be fixed.
- Drivers door speaker did not work at all when the radio was replaced with the 740 headunit. Kept eating fuses. Speakers were replaced with aftermarket drivers at some point, probably with the alpines. Found burn / scorch marks where the driver's door speaker was shorting on the door metal. Fixed.
- Valve cover gasket was leaking heavily. Fixed.
- Transmission pan is seeping substantially. No rust though!
- I (think) the center driveshaft support bearing might be starting to die. Something back there likes to sing. It's speed tied and not RPM tied. Those ghosts better start paying rent.
- I have replaced everything in the rear suspension except for the trailing arms / main trailing arm bushings with poly / adjustable IPD panhard and torque rod bits.
- I did the struts with B4s, Lowered slightly w/ Lesjofors springs (4595804) from FCP. Rear shocks are KYB Gas Adjusts (1206641). Remember how I said someone did the suspension at some point? Best guess is very very early 2000's based on what came out. Definitely not the factory bits but oh boy were they still blown/aged. Rode awful. Much better now but the rear trailing arm bushes still clank like a kitchen in a dryer.
