940driftsled
- Aug 18, 2025
- Finland
Hey guys!
I'm having some issues with my M90 transmission (of course). I just swapped from a M47 to this M90 on my B230F 940, but apparently this M90 is possessed. The car has dog-dish flywheel, custom homemade transmission crossmember/mount, and a fresh clutch setup.
Now onto my symptoms:
Sometimes I’ll check that the shifter stick is visually and physically sitting dead center in the Neutral position, but when I let the clutch up it starts grinding and after adjusting the shifter a bit the grinding stops. Otherwise I don't have any grinding when selecting any gears. This has happened previously and when I try to push the car with the engine off its like it would be stuck in a gear even though I can clearly see that it is in neutral.
When I start reversing I obviously select reverse gear and let the clutch up, the car moves back a bit clunkily and when I push the clutch back in the car suddenly stops like I would've slammed the brakes. When I tried to select 1st gear after this I physically got blocked when trying to get the gear in, I let the clutch out and then in again and then suddenly I'm able to select 1st. With the car off I can select every gear with no issues, and it is clear that it has selected a gear. There is no slop in the shifter linkage under the car either.
Has anyone had these symptoms before and should I throw this transmission in the bin and buy a new M90 or even a ZF?
