First Volvo - 1988 760 Turbo
Pic of my 700 when I first got it (20 years ago), twinsies! I went the V8 route. TX sun was not kind to my paint and faded it
Looks great, the Colorado sun is similarly brutal on paint. Mine seems to have been resprayed at some point, even with all the imperfections I've been really happy with it. I love the early 760 chrome wheel trim on yours, I wish they would've kept it on with the facelift.
I'm especially partial to the early taillights myself, something about the chrome trim and square lenses I think fits the car. Hopefully the interior will start to feel deluxe again after I finish restoring the headliner I've been putting off gluing down and back into the car.
Looking forward to getting deep into some performance testing at some point. I've been keeping notes of where the local dyno shops and machine shops might be able to help me out.
  • Like
Reactions: Dan
Mud flaps were super straight forward to install. Required a little drilling, was a little surprised they used different fasteners for the front vs the back sets. They're much more visible in real life vs the photos I think they should've come factory installed.
Theoretically, the other half of a 16 valve build seems like a more built up transmission. I've seen a few manual swaps but all the cool kids these days seem to be doing 8hp swaps. Ideally something on the smaller side, from a rear wheel drive model. Found it via marketplace, pulled out of a rear wheel drive BMW with an N55 engine/torque converter. I'm told 71k miles, the seller had pulled the oil pan and the oil seemed to be free of any metal shavings.
So I came home with a $250 8hp45 and the N55 torque converter.
Domi-works makes an adapter for the bell housing to the redblock. Looks like I'll probably also need to pick up an N55 adapter kit and some other odds and ends. At a minimum, a new plastic oil pan/filter too. It's dated 2014, so I'm pretty sure this should be controllable via MaxxECU.
So I've got some more parts to acquire, including a MaxxECU install that should probably go in before I actually pull the engine. I'll either need to pull the TCU or flash it myself.
Next up: This is my daily, so I'm trying to keep down time to a minimum. Great reading from Ando Engineering: Volvo 240 8hp swap
It looks like I'll need to get it up into a stand and start trimming some of the unnecessary hangers. I've ordered a new oem oil pan and a unit from ali-express that should allow me to do some diagnostics, as well as flash the firmware files. Hopefully I'll just be able to flash it without needing to pull it and send it round trip through the post.
Installed some hub-centric spacer rings for the aftermarket rims. OD: 73.10mm, ID: 65.10mm
I'm glad I did, they've really smoothed out some of the road buzz.
Went ahead and got my emissions test, the first one since I installed the Magnaflow cat.
HC: 0.2802 Max: 1.5
CO: 4.7821 Max: 20
CO2: 391.2010
NOx: 1.0425 Max: 3
If memory serves, this is lower than when I picked it up/had the oem cat installed. They gave me a hard time because the driver side windows don't roll down, I'm sure they thought it was a sting. Managed to convince them to do it with the passenger windows rolled down. At least emissions are done for another couple of years.
HC: 0.2802 Max: 1.5
CO: 4.7821 Max: 20
CO2: 391.2010
NOx: 1.0425 Max: 3
Do you like your MagnaFlow? I'm thinking of doing the same when I get my turbo back system built. Curious which model you went with?
I do! I was already installing a Simons 2.5" cat-back exhaust and since I live in a CARB emissions controlled part of the country, I went with this one: Magnaflow (part number: 3322949)
It was very convenient to buy something off the shelf that was pre-bent and basically bolt on ready, including the O2 bung. I ended up trimming the flare off the tail end and it fit easily into the rest of the exhaust.
This is the best picture I've got comparing the original vs what's installed now, including the catalytic converter.
There are almost certainly less expensive options but at least I made $40 recycling the original converter.
Some of the swap parts have started to arrive:
Starting from the top, the Mini ACDP-2 from AliExpress & associated connectivity modules including the 8hp:
a MaxxECU compatible e-pedal out of an '08 v70:
a BMW gear selector out of either a 5 or 7 series with the 10 pin connector:
and an oem zf 8hp45 oil pan, complete with filter and bolts.
I've also got an appointment with some local classic Volvo specalists to finish up the R12 to R134a conversion at the end of the month.
Continuing on a theme: My domi-works adapters, accessories, and oil cooler setup have arrived.
I also put in an order with a forum member, Willettrun Automotive, for a MaxxECU Gen 2 Track kit that looks like it'll be here tomorrow.
and I finally took it in for some professional assistance for the air conditioning conversion. The fine folks up at Swedish Motors in Boulder completed the R12 to R134a conversion with a kit they had identified and I had ordered in from Skandix. When I bought the car, the a/c was cold but it didn't last long so there had to be a leak somewhere. They were able to identify a pinhole leak on the high-pressure side of the system and used a metal epoxy that's apparently rated for something like 390F and 14,000 psi.
With that bill paid, the R134a conversion is now complete. Air conditioner is blowing ice cold again and I'm confident it'll stay fixed. While they were in there, I had them do a once-over of the mechanicals because it looks like we're moving back to Texas so I've got about a 900 mile road trip ahead of me. Nothing additional was suggested and even got some kudos from the tech for it being so clean.
I'm hoping to be able to squeeze one more specialist shop to install an upgraded rear differential before we move. After the move, I expect I'll have some more time on my hands and will tackle installing the MaxxECU Track unit before pulling the engine and transmission in preparation for the 16valve upgrade and 8hp45 transmission.
yeehaw~
Looks like the MaxxECU and gear selector harness have arrived. Super nice bit of kit
I still need to acquire some pistons and rods for the 16 valve rebuild but will focus on it after the MaxxECU install is sorted.
Now I've gotta finish packing up the house before the road trip. I'll leave y'all with a nice view of the Rockies as seen approaching the city of Boulder.
