Free VE Table Corrections — Drop Your MSQ and a Datalog, I'll Do the Rest
I tend to stay on the safe side of things, but now I have an idea of what you want, I am going to add the rows to spread out the cells a bit more to get better coverage, and this exposed a bug when I got into everything the Accell Enrichment filter was not catching everything in the speeduino version of my tool. So... Let me work on this and get you another table to load with the fuel left alone in the cruise area, and another thing adding one point of fuel has its constraints might be better to set your cruise to 15.1 and then if I add fuel to it we can get it spot on to 14.7 as adding fuel with it being 14.7 will lower on the rich side.
I appreciate the feed back this is helping me to improve the tool. Also, the data tells me exactly what you were saying which proves it is accurate.
Would you like me to set the AFR target table to 15.1 during data logging of these tunes ?
Sure thing, just for the cruise tho. and let me go back over this,, I want to make sure I get this right. The fixes I put on these are very minimal they are ok but I want to make sure I am not missing anything, and when you mentioned that
also seems far more resistant to go rich at the boost threshold zone.
That was due to the Accell enrich filters not firing on Speed logs. That caused some false rich readings.
Fine to run now pulled some fuel out of cruise and spread the cells out, I will look at this again after work tomorrow to make sure that I have not missed anything, thanks for allowing me to help you with this and giving honest feed back this is the type of data that i need.
Go ahead and run the Cell spread version, and try and get me a couple logs, I have worked it out where I can run multiple logs at once to give me better coverage. Let me know how that goes, this way things are not so cluttered and we get better readings.
If you want to, sure. I am quite happy at the moment though.
Biggest thing is I need to add an IAC valve to get my idle working properly. But anything off idle is fantastic.
Well, that and the turbo.....
@HiSPL Send a log of a cold start and 4-5 minutes of idle. Also a separate already warmed drive. whenever you get a chance.
@Jamesmoore Thanks for allowing me to try and help, I do not run speeduino , so I can not test, having your feed back helps me help the tool along.
https://www.mediafire.com/file/8c4cchpm2ksgv43/cell_spread_2_210283.mlg/file
https://www.mediafire.com/file/ig3sghwzfx1m7u2/CELL_SPREAD_3_210304.mlg/file
see the msq and then 3 drives worth of data log. i set the afr target table to 15.1 in the cruise zone. although not sure what difference that make as i believe the only time its referenced by the ecu is when using open loop adjustment? ive got that switched off.
not sure what to think, mostly too lean im seeing an average of 15.2. some areas are leaner, some are richer. seems to be a bit around 2000 rpm low load that seems to be hitting 14.7 but the rest is off.
car definitely feels like its got less power and im having to drive closer to boost threshold to get it going.
let me know what you think.
Interesting that you say less power, I only pulled fuel from the cruise. one point only. Let me look at this....
That might be just me imagining that, I was driving with less haste due to the lean readings on my gauage
Strange how only one point pulled has made it run significantly leaner
ok, something that I did not account for spreading the cells out with your exsisting AFR table. Makes going into boost too lean, so let me work on what your afr needs to be. With the cells jumbled before the afr was correct for that setup, now not so much.
So spreading the cells for sure caused the issue, let me work it out thanks for doing this with me and being open minded about the whole thing. I think looking at the afr table the boost targets are a bit lean anyhow..
Edit: So you were correct it was for sure less power and that I own but it wasnt me removing fuel it was not accounting for the afr when the cells were spread, I will add some fuel and lower the afr targets on going 70kpa to boost. Data is telling me exactly what you feel.
View attachment 40399View attachment 40397
Sweet
I find it super interesting that your able to actually see what I’m feeling on multiple occasions haha
As previously discussed this is all just trial and error until I get round to my final professional dyno tune. Whilst the car is a daily driver I really don’t push it and only live 4 miles from work.
I’m mostly just interested to see how accurate and smooth we can get the cruise AFRs ! As I’d be open to changing these after the dyno tune. Anything in boost above 5psi say can be left to how my tuner wants it to run
Yeah I have been working on this thing for two years, just not many speeduino logs : As you see this is just one of the drives you uploaded you are going lean into boost. Let me work all of this out and get you a corrected table, give me one or two more passes to work this out, please and thanks for sticking with me on this.
Run this one I feel like you gonna be pretty happy about it this time.
The report will not mean much as I am adding fuel in anticipation of the AFR changes I made/
I’ll get back to you on this ! Have a busy week at work lol
Cheers
Worth a shot, if it makes it worse just switch back to the latest tune, this one includes the new fuel table as well.
