ArchStanton
- Jul 26, 2026
I know this is the up-teenth fuel pump relay discussion.
1988 240. I was experiencing intermittent stalling at speed, especially on hot days. The problem temporarily alleviates if you let everything cool down. So I replaced the fuel pump relay. The old one only looked to be about 10 years old. The problem did not go away. Popping the cover off the fuel pump relay, Coil 1 clicks on and then gets hot with the ignition on, even though fuel pumps are off. Hot enough to can't keep your finger on the coil after a minute or two. This is with the engine and fuel pumps off. The relay is drawing 0.9A on pin 30, about half of which gets output to the ECU and half to the MAF. The female connector block and all the spades look good and seem to make good connection. Wiring looks good. Cleaned up the grounds. I replaced the 25A fuse and holder behind the battery because it was in a bad way. No change. New and old $20 cheapo fuel pump relays have the same behavior. If I disconnect the wires that go to the MAF and ECU the input current on pin 30 goes down to about 0.2A, but coil1 in the relay is still heats up. I don't see any broken or melty solder joints in either relay.
The heat is definitely coming from the relay coil. Is that normal? At this point I've ordered a nicer $50 relay. Not sure what else to do? I replaced the in tank fuel pump a few years ago when it failed, and I replaced the main fuel pump last year because it was getting noisy. They work fine and draw the proper amperage. But they're not even in the circuit when this thing is cooking.
My stop-gap solution is to position the relay under the floor blower and crank it to 4.
Thanks!
Thanks!
