Fuel/Spark tuning for LH 2.4/EZK with TunerPro!
HI All.
I have a 984 to go into my 240 turbo conversion.
Does anyone have a compatible BIN with no immobilizer I could use to get the old girl running when i have finished.
Cheers
Gary
i don't see a reason why they wouldn't work aside from physically. the square pins are 25 thou vs the circle pins being 20 thou
The IPDdown lh2.4 tuning program if you open the bin and save it, it will automatically fix the checksum in the bin. Easy as it gets for checksum fixing. LH 2.4 editor is the name of the program.
Cheers mate. I’ve been struggling to find the program and a download that works.
what bin do you use? I can find you which byte to set to zero to ignore that checksum check if that is acceptable to you
It works :cool: https://turbobricks.com/index.php?threads/1994-945-turbo-ultimate-dd-build.363707/post-6328006
Tracing works too?
Did you make ADX history tables for AFR or something?
Tracing works well, it's fast. But I'm not using an ADX with it. Mostly just watching the trace and making small adjustments at a time.
Works with the EZK as well.
The worst thing about my Cobra unit is that it never saves the bin more than a day or so. I have no idea why, but no matter what I do it will never save the bin for long. Sometimes it saves it for 12 hours, sometimes it saves it for 2.
Hm, I want to do ADX extension, because my plan is tune AFR first, then will tune ignition for power
