Wobsmangbaffler
- Nov 16, 2020
- Hampshire, United Kingdom
Apologies that this should probably be in TBOT but you cant upload pictures directly there... blame my nutcase govt for banning imgur...
Prologue:
I first discovered Gatebil whilst watching the Bamse's Turbo Underpants series on Youtube. For the uninitiated, Gatebil translates to "Street car" and is a 4 night festival that runs at several different Scandi circuits throughout the summer. The main staple of the event is the on-track drifting action. The variety is pretty impressive, although there were plenty of RWD Volvos on track, they are definitely becoming thinner on the ground compared to footage I have seen of past events.
The car:
My steed of choice was my daily driver 1990 740 "facelift" estate. This is my first car that I have owned for 7 years at the time of writing this. It started off as a B200F (LH2.4 NA) manual car that I then swapped a B230FK, 531, 16T, and M90 into in 2023. I had it on the dyno making 262hp calculated crank power at 20psi. I took inspiration from James May's 850R setup in the Top Gear Africa special for my sleeping / storage arrangement. The window blackouts are cut from an 8'x4' sheet of Correx plastic sheeting- it is flexible enough to be removed easily, whilst the double wall permits for sufficient blackout-ness. Also not seen in this picture is a cut in the plywood base that allowed me to separate the rear ~2' at the rear of the car. I placed this vertically so that if I got rear ended whilst driving, the whole board would be shunted into my chair and cause me to be pinned against the steering wheel.
The route:
The journey in total came to 3,275 miles all in, and used 139.219 US gallons. This comes to 23.5mpg on average. I chose to get the ferry from Dover for cost efficiency instead of using the channel tunnel, arriving at Calais where I spent the first night. The next day I drove to Utrecht in the Netherlands to see a friend for night 2, and night 3 was then spent in Copenhagen in Denmark to see work friends who are posted there at the moment, before I made it to Sweden on day 4. I spent 10 days in sweden, travelling to Gothenburg for the Volvo museum, Stockholm to see Vasa, and plenty of the Swedish countryside. For what its worth, the car did not break down once for this trip, and used about half a litre of oil (leaking, not burning) which sufficiently coated my chassis ready for the salty roads this winter
The main event:
The camping section for those staying the duration of the event is right next to the track behind the concrete barriers. I had been parked up for maybe 20 minutes before these legends adopted me, after I had explained my journey and that it was my first time both in Sweden and at Gatebil. They love rolling coal at Gatebil, and the Caddy had a Mercedes diesel engine swapped into it:
The paddocks were open access 24/7 for free roaming sober or drunk (I'm not sure I was sober for any of it honestly, I think everyone else feels the same way).
There were both grassroots and professional cars there. Most notable cars in attendance were Kevin Brunberg's kevlar 740, Blacksmoke Racing's Mercedes S123 with >900hp from an OM648, and Peter Bjork's Lamborghini V10 powered 240. I will just dump a load of the paddock photos below for you to admire:
Prologue:
The car:
The route:
The main event:
