getting 250/300 hp goal in my 940 lpt from '96
striepe
hey guys i am looking into upping the horsepower on my 940 b230fk m90
i have installed a mbc so far but i want a bigger turbo i'm thinking about a 16t but i don't know anything about putting on a bigger turbo so i need to know what injectors chips etc. i need for this goal
Ive found this site selling 16ts and complete 3" exhaust is this good?
https://martelius.com/en/exhausts/j...rbo-big-power-upgrade-kit-vinolla-pakopesalla
greetings from the netherlands:cheers:
Looks like the only turbo they have in stock is the 19T, that will get you to your desired power level 100%. Having used that wastegate relocation bracket they offer, I hate it. We had to cut it up and reweld and all kinds of stuff to get it to work. You could get one from Yoshifab, but even better is the one that Dutch company Luca Car Mods used to make. I think they're on the fence about bringing it back, maybe you can help persuade them. It was excellent.
If you're looking for 250-300 engine (not wheel) horsepower, look here at https://www.redblockpowered.com/. It's got a recipe that he used to get to various power levels, and sells some of the components. He has a good relationship with https://www.harrieco.nl/, which you might find helpful.
240-250 engine horsepower takes some planning and execution, but isn't too difficult. More than that can get quite a bit more complicated, but is still accessible.
Hope this helps, good luck with your project, and welcome to the group!
What about injectors? And Ive heard a 3" maf from a 960 is better than the stock 2.5" one
It is a good idea to use available calculators for injector sizing - one option
Same goes for air filter. That has to be able to support the required volume - Filter Calc
Have you done any research on the overall requirements? A good start would be to look through some of the builds on here.
Also letting us know what your mechanical abilities and equipment / tools you have access to. Can you weld if you need to modify the down pipe for an angle flange hot side, for example?
The link i put in sells turbo s and complete exhaust with down pipe put welding and tools wont be a problem my friend is a mechanic so thats a bonus
Injectors/MAFs/etc are not tuning tools, so you'll need to select a power goal and pick the correct components and build to that. Like I said, about 240-250 is the break point for the small MAF, and that power level would require injectors with a modest flow upgrade. lookforjoe's advice on scrolling through some of the builds on here is probably a good place to start. I would warn, however, that sometimes people just go for numbers and not results: more is not necessarily better. The Garrett website has excellent tutorials on how turbochargers work, results that can be expected when they're selected correctly, and what can go wrong when you haven't selected them properly. Just because your turbo runs well at 12lbs doesn't mean it runs well or even makes more power at 20lbs.
Also be attentive to the things that aren't said...how are these cars used? Does it make good power but drive poorly? Is that how you're going to use it? Stuff like that.
Is this your daily drive? Make sure your car is stage zero so you can take full advantage of your upgrades and service is up to date.
yes every thing is up to date execpt for the pcv but thats coming in the mail
Get better intercooler before anything else.
Honestly this.
Can't stress enough how much of a performance boost it is.
I swapped to a 16T and was totally underwhelmed by the increase and it was just after installing an upgraded IC that it made such a significant difference.
I have the KL Racing one.
Absolutely - install a decent intercooler such as the KL Racing, stock will heat soak quickly and is also restrictive when looking at any decent hp gains. Own a 1994 945T that has one and could not be happier, fits right in with no modifications required.
From there I suggest the early ( 1992 -94 ) 960 3" MAF, I used couplers found on Ebay to retain the stock airbox setup ( good for around 300 hp ) so no need to modify ( cone filter etc. ). Beyond that I used green top injectors from an S 60R ( need to bypass the injector ballast resistor ), IPD camshaft, 16T turbo with 15G exhaust housing to maintain the stock down pipe though you can get a correct 3" version to fit the 16T from MKM in Sweden. One should get better flow using either the straight or angled exhaust housing of course, the 15G one is more restrictive but was a simple bolt on.
I also use insulated intake manifold gaskets to reduce heat ( makes a difference ) and an early 960 ( pre 1995 ) oil cooler that mounts under the lower rad support, one needs the early 740 oil filter housing and water pump return pipe with that and custom made oil lines. Not necessary per se but I dislike the oil / coolant heat exchanger Volvo used and the short hoses, one less issue with coolant leaks, especially into the oil and it does happen.
You can have Stoni in Germany make custom mapped chips for both the 2.4 LH ecu as well as EZK if desired ( more advance ). He is well versed in the Bosch LH system and knows how to make it work well. I had the 16T installed without doing much else and the increased flow had the stock ecu hitting fuel cutoff so going to the 3" man and chips is a must to really get anywhere. Stoni uses the boost solenoid from the 850T with a small board that controls boost output to 13 psi but one can easily increase the threshold, it mounts anywhere and only use a few wires to connect. I never installed it ( yet ) as I have a basic manual boost controller.
chipsfrb.html
I am guessing somewhere around 250 hp, though I also have a 2.5" exhaust and gasket matched the exhaust manifold where the turbo mounts as it is restrictive and can be opened up a good amount, one of the reasons they are prone to cracking.
Once you increase hp to around 200 + it is a good idea to invest in a reinforced rear sub frame as well as BNE adjustable torque rods. It is a weak link in the rear suspension design. I also added late 960 reinforcing plates for the front control arms. Upper and lower chassis braces are a plus along with IPD sway bars. No use having decent power without a well controlled suspension.
I am probably missing something - my 945 is an automatic and so far the transmission is surviving but then I do not do things like hard acceleration from a standstill. The extra power output is great for merging on the freeway and simply having fun at times, car cruised easily at 140 kph.
If you have any questions just ask. Beyond this are larger valves in the head and there are other camshafts available from KL Racing etc.
Should add that once you let Stoni know what you are using he will custom map the chip. He can suggest as well if not sure. For myself the 16T / green top injectors / 3" MAF were the foundation. No more fuel cut out which is a definite plus.
