OVERDRIVE
- Jul 31, 2017
- Brooklyn, Neu York
I'm trying to get some chips to learn fuel trims down low (1800-2100rpms) under load with an automatic. Of course I'm only able to do this from a stop for a brief moment. B230F/AW70. Shaved head, V cam, pretty normal stuff.
1: Can I disconnect the kickdown cable and do a lot of WOT pulls from say 40 to 60mph? Is there a concern about a WOT shift while the transmission is seeing zero throttle input?
2: I am not sure how lean I am but it's definitely causing detonation and pulling a lot of timing at heavy loads down low. Is this interrupting how the LH is learning?
3: I've put 450 miles since resetting the ECU trying to get it to learn, would it learn faster if I reset it then immediately went and did this experiment?
