Grind it, Drill it, Weld it, F it?
  • Grip it
    Votes: 0 0.0%
  • Grind it
    Votes: 0 0.0%
  • F it
    Votes: 0 0.0%
  • Total voters
    1
HiSPL
Fanking Champion 1993
College Station, TX
I got this 90+ manifold. I bought it cheap knowing it had this crack, and repair.
It's been welded up (I think poorly, but I'm no pro) but the crack has propagated to the inside.
So. What are the thoughts here? Do I drill the ends of the internal crack and rock it? Do I weld up the internal crack? Do I grind off the old fix and redo it completely?
What are your thoughts?
F it?
Wear a condom, my brother in Christ 🫡
I think I'll at least grind the current weld back. It's like 1/4" proud of the surface. I'll look at the porosity and see what we see. If it looks solid I'll just run it as-is. I don't want to weld cast iron.
It’s cast steel
Edit no it’s cast iron
Just put it in the oven at 450 right before welding or torch it
A crack like that would take a braze repair really well.
I mig brazed my cracks with ERCuSi-A after drilling the ends, beveling, and preheating.
Cracked again in no time, unfortunately. Maybe there's a better alloy but silicon bronze didn't work for me.
The part that bothers me the most is the fact that whoever welded it, didn’t drill the ends.
I’m afraid I’m gonna have to clean this up and redo it all. Probably have to stick weld it to get the penetration. I’ve got a horror fraught multi process machine. Not sure the tig has enough ass on it to do this job.
Drill out ends and grind out all weld material/crack.
Pre heat to approx 300C.
Easiest is MMA, use high nickel content electrodes.
This material has a similar coefficient of expansion as cast iron, so residual stress from the welding is greatly reduced.
You might peen the weld area after welding.
Then gradually cool the part down.
The best is using a cool down oven, but packing the part in glass wool also might work.
Mig welding with ER70 or similar is a bad idea, almost certain to crack again.
When I get them repaired, tig is used. You just have to know how to do it. You can do it with mig but you need the correct nickle wire to do it. Doing it mig, you definitely want it hot enough to penetrate. But sometimes the material will burn off too fast if it's really cooked.
