Moisttowlettes
- Sep 25, 2022
- Suburbs of Chicago
absolute honor witnessing the end of a eraThus ends Hacked II, unless he decides to back out. Then I'll be looking into an engine swap of some kind.
I've been summoned?
Yeah, that's what we tried. We pulled it out a little (from being all the way "in") and it did the same thing, but worse.The pump timing can't be that far off if it's running at all. Loosen the bolts and twist on it, hillbilly tuning style. That's actually how I did every VW 1.6l I ever worked on because I didn't have the dial and wasn't going to bother getting one (I was younger and much poorer).
Nothing in the cabin that I'm aware of, no. Again, I'm not super up-to-speed with diesels, but there's a cold start device on the side of the pump. It includes a lever that pushes against the throttle plate when cold. It's automatic, and to my knowledge there's no way to control it manually. We tried starting it with and without the cold start connected, and it didn't have much of an effect.I forget, do these have the advance lever in the cabin for cold starts?
Yep, no way to put it backwards.Yeah, I realized this a few days ago when timing the IP pump. Somehow it never occurred to me. I'm not used to dealing with motors with overhead cams, so I miss things like this, mkay?
At the very least this confirms my cam timing is good and that there's no way I put it in backwards... right?
The throttle shaft thing is only one nut to remove, so I guess it can't hurt to try and see if that helps. I took it apart probably close to a year ago, and am of course cursing my 1-year-ago self for not marking it.Throttle shaft - yes, you could have missed the alignment. You should always mark the plate and the shaft before taking it off. You're probably not too far away, try putting it on one spline CCW. Also, it could be just the case of still having air in the system.
I hate to say it, but it's more or less a done deal at this point. The entire reason for my sudden change of pace and desire to get it back together in a (relatively, by my standards) short timeframe is because I was trying to sell it. I'll spare you the sob story, but I'm not in the best financial situation right now, and I would much rather have the money than a moneypit.C´mon! You are almost there! Dont sell it. You can do this. Just add some patience
Oh man, don't disparage yourself. Life and money are hard sometimes.The throttle shaft thing is only one nut to remove, so I guess it can't hurt to try and see if that helps. I took it apart probably close to a year ago, and am of course cursing my 1-year-ago self for not marking it.
Buyer's remorse on my part? Definitely. I originally had plans to engine swap it, and I had actual heated shop space (with a lift!) lined up with a friend and it just didn't work out due to a number of complicating factors. Thus, I ended up in the same situation as the 144, working on a car that needed a lot more than I could give it in the cramped space I have. Sure, if the pump timing had been dead-nuts (or if it is indeed a throttle adjustment issue), it would run but the car still needs every bit of rubber on it replaced, and I don't think I can give it that. Even if I did somehow manage, then I'm left with what is at best a really slow weekend car that uses the most expensive fuel available at my local pumps.
I feel a lot better about pretty much breaking even and handing it off to someone who is both a lot more qualified than I am to deal with the D24, and someone who's more excited than I am about having a basically rust-free stick 245.
Once I have some comfortable, stable income, yeah probably. I have some ideas floating around about what hopeless project I want to get into next...Do you think you will end up getting another brick in the future?
So there it is, the end. For real this time.
So there it is. The official end of Hacked II. I'm still hunting around for jobs, but if that goes "well", I might have something new to post about come the spring or the summer.
Thanks for reading so far.
Not as much as I wanted to, sadly. I think my biggest accomplishment is that I got the timing on the engine so that it wouldn't explode. Otherwise I don't think I would have been able to sell it.Well, darn. You did do quite a bit to keep this car on the road. Good job.
I hope you're right... third time's the charm, right? I think I'm going to try for a redblock car next time.Yeah, the number of non-running project cars I've sold due to deciding it wasn't a great path to go down is not small. It's always a thing, and there's no shame in it. Everything you do stacks more knowledge away for the future, and future projects . Just cause this one didn't pan out, doesn't mean the next one won't.
