fatcatbestcat
Professional Hack
- Oct 1, 2019
- Mississauga, ON (Canada)
A Very Late and Very Image Heavy 'Update'
Yeah, that statement aged poorly. Five months later, I now have the tools... and the time to work on the car again.
Not a valid or relevant excuse, but I have long covid, so I get fatigued super easily and working on this car in the heat is killing me. I do want to get the car driving before August, but I've set goals like that before and not achieved them.
Anyway; here's what I got done this week. Not much, but it's a start.
Along with the tools, I also grabbed a pair of D24 greenbooks for quick reference. I'm aware there's PDF-ified versions online, but it's nice to feel physical paper, and I don't have a laptop to bring out to my garage anyway.
I had gone through the garage a few times last week looking for other things, and I checked the car for rust or any sign of animal damage (resident raccoons - more on that later), and fortunately me not touching the car does not seem to have made it worse. I killed the battery in January doing a cold start experiment, so that's why I have a fresh one in this picture.
I'm not sure exactly how this happened, but the line to the coolant expansion tank got clipped and seems to have leaked coolant all over the battery and tray. That was fun to clean up.
Replacing timing belts means removing the rad, so that was the first thing for me to procrastinate about. I hate dealing with coolant, and it's especially annoying to deal with spills on an old concrete floor that is covered in holes.
Also, for some reason, the clamp on the lower rad hose was turned at such an angle that I had absolutely no hope of getting a screwdriver on the nut.
At the time, it seemed like a smart idea to just unplug the overflow tank's lower hose to drain *some* of the coolant and make the job a little easier. Naturally, the ensuing jet of liquid shot past both of my splash pans, ran straight into the firewall and then dripped to the floor of my garage.
I then proceeded to not touch the car for a couple days after being so disheartened by this embarrassing spill...
There were some huge storms in my area this one day... power went out, trees down etc etc. The day after the storm, I check my garage to find not one, not two but three deceased baby raccoons right out front next to the car.
That was incredible fun to clean up. I think this car might be cursed.
At any rate, my solution to the lower rad hose issue was just to pull it off the engine side. Was a little awkward to remove it with the radiator, but it did work out.
SO much more space to work with now!
Thanks to v8volvo for providing the tools! This one here is used to remove/install the crank pulley, but the manual also calls for its use to turn the motor over to TDC when doing timing jobs.
This is somewhere near top... I will confirm later when I go to remove the pump.
I also have this nifty tool to remove the (very tight) nuts on the injector lines.
These ones in particular were rather annoying to get to. There's a lot in the engine bay that has to come out.
This is the vacuum pump, removed. Note the wires at the bottom for the glow plugs.
Lines off!
That's all for now. Hoping to make some more progress this week.
Progess.
Lines off!
