CoconutColin
- Jun 17, 2003
Here is the video
The car was parked for the winter and then started doing this.
Can you please help me. I need to get to workIs it really you
I like what you are saying. I unplugged thr throttle position connector along with the MAF and it didn't seem to change anything with the drive ability. I need a nice diagram of the circuits and if possible start checking the continuity of every wire.With a carburetor, those symptoms would say bad accelerator pump.
With injection, similar results with a bad throttle position switch.
Does it click just off idle to tell the ECU "more fuel please"?
Does it show proper continuity at its 3 terminals?
Did the mice nibble any wires in their temporary winter shelter?
Where are you located?Hello
Update is the AMM pin 2 to 3 is 0.00 volts.
And o2 sensor is 0.351 volts.
So I'm going to look for a AMM before I do anything else.
Ontario Canada.Where are you located?
I did that and got 13.4 volts. Because I did it while it was running I checked the voltage of every pin because I was looking for the hot full voltage.This can explain why disconnecting the MAF the engine ran in the same way.
As a last check I suggest you to verify that the MAF is not working because it is broken and not because it is missing the power supply: between pins 1 and 5 you must measure 12V with ignition key ON.
P.S. to take measure you had not disconnected the connector, right? I believe that you had rolled back the sealing rubber of the connector and made back probing
And yes. I back probed it connected to the amm with the rubber peeled backThis can explain why disconnecting the MAF the engine ran in the same way.
.I think on a '86, that fuse 6 is unused and fuse 4 is for the tank pump only. The main pump is un-fused off the fuel relay.
With key off and the MAF unplugged, can you measure the resistance of pin 2 in the harness to ground? Pin 2 is sensor ground and It should connect to chassis ground through the ECU. Alternately, at idle with the MAF plugged in, can you measure Pin 3 (MAF sensor voltage) to ground? It should be around 2volts at idle.
