HiSPL
Fanking Champion 1993
- Jan 8, 2015
- College Station, TX
In a world where people are paying 400 bucks for Ben’s qsrc’s, this doesn’t seem too out of line.
A new project is brewing in the garage... an engine!
I'm going for more mid range power, more top end, better response, no burning oil, and least likely of all, no oil leaks.
Engine:
-R head (Dual VVT) - Gotta sort out the cam sensor clearance, prob going to roll my own trigger wheels to use the 850 style cam sensors
-2.4L block - boring out to 2.5 (I know, the horror)
-Mahle motorsport 83mm pistons - sold as a Mk2 Focus RS PN, a shop in the UK had a set sitting on the shelf collecting dust.
-K1 rods
-TSP700 cams and valve springs
-Ported head (TBD)
-E-throttle
Time to retire the VEMS, it's been flawless but I've reached the limit of I/O, I want solid knock control, ethrottle, no soldered on jumper wires, and good documentation.
-Maxxecu Race Gen 2
-Life Racing PDUX2
-New wiring harness
No plans for thatNice!
Are you going to shim the block? Blockguard?
Still rocking the M90, at some point it'll get swapped with a BMW 6 speed. Not sure when that'll happen.And what of the $240 transmission? Has the M90 been replaced?
Awesome, can't wait to see your progress. Can you share more info on the cams / valve springs? I haven't heard of those and would like to keep them in mind for my setup at some point down the road.
Will you be using the Maxxecu pre-terminated engine harness, or building your own?
Staying with the same exhaust manifold / turbo?
| TSP700BRC | Duration In Crank Angle: 280 Valve Lift: 10.5 |
>G42-1450 good lord. Can't wait to see what this combo puts downAwesome man, The G30-660 is a sweet turbo. I have a g42-1450 going on my V8. They seem to perform really well. Even my old GTX now that I got the car and everything all figured out is a ripper.
That’s a long distance machine shop visit! Larry’s has done all of the work on my engines/heads over the years. Great guys, really nice work. Can take a while during their busy season and they’re not cheap but worth it.Sheesh, slow to update here. Parts pile is growing larger. I'm about ready to yank the engine out.
M90 will come out too, GS6-45DZ is going to take its place. I'm thinking of listing the entire driveline including turbo and vems for sale once the new setup is in.
Engine is off at Larry's Power in CT for the full makeover including cnc porting.
Entire hot side will be getting some zirconia exhaust coating (header, turbo, downpipe).
Taking a week off to work on the car in late may. Expect more updates then!
In the meantime, new color scheme.
It sure is a ways away but I didn't feel like messing around hoping a local shop would do it right. Seems like it's worth the wait!That’s a long distance machine shop visit! Larry’s has done all of the work on my engines/heads over the years. Great guys, really nice work. Can take a while during their busy season and they’re not cheap but worth it.
