Ayce
- Sep 7, 2025
first I want to say, obviously, I am no expert, this is my first time doing anything like this. I have seen only one other posts on this topic so I felt like I should post mine.
Photos
Basically what I did was:
get the intercooler in there where the rubber on the front was up against the ac condenser- this requires hammer,
measure from the points that the ic sits in on the radiator lower mounts and figure out where my holes needed to be for the radiator to fit directly vertical,
towards the front of the car, I had to bend the 940 rad support flat to fit on the flat 240 rad support. I actually had mistaken the rear for the front so I bent the wrong side. The only thing this changed was the lower rad supports don’t perfectly fit into their holes , they are prevented from sitting flush in the middle by the imperfect bends I made.
And the rest was just cutting and welding really. I made a template of the cut out that the radiator fits through on 940t cars, planning to cut out exactly that but I ended up just cutting a hole for the 940 rad to sit in.
i had to widen the metal behind the ac condenser (headlight support?) via hammer. I also had to cut notches for the intercooler in/out to fit. This requires bending the bracket for the ac component.
I also had to lightly clearance with the hammer for the intercooler to fit under where you put the tools.
I don’t think this would have been fun with the motor in the car. Also I have the water oil cooler system. I am annoyed that the radiator isn’t getting airflow below the mounts. I probably am going to holesaw 4 or 5 holes just for some airflow.
I am ready to hear how this will barely affect my cooling performance and how I should of just got a new universal radiator and fabricated something from scratch or better yet just left it oem
I am not done with this project yet. I still have to figure out a downpipe (using 940 dp), wire the e fan, expansion tank mount(annoying), figure out a battery, afr gauge , boost gauge, boost controller(not sure if I need it), and figure out if it all works. I am very happy with how the radiator figment came out though and I am super excited to get this thing on the road.
if anyone ends up doing this I encourage you to post about it because as far as I am aware thisreddit post is the only information out there. Maybe I am wrong.
Photos
