How to remove fuel inlet line from fuel rail?
Two long flare nut wrenches setup so you can squeeze them together for loosening. spray some penetrating oil on the junction. Let soak for at least a half hour.
Thanks I tried ur advice but no luck, this thing is really stuck on there… trying more penetrating oil now for longer
Get someone to help you by having them hold the wrench on the fuel line hex fitting. Then, use a block of wood to give your tubing wrench on the fuel line nut a sharp blow. Make sure you are already holding the wrench to take up any slack in the connection. An impulse works better than constant torque to get any connection to come loose.
Might be near impossible to find a helper to hold one wrench against impact, but I agree the impulse works best if you could get one wrench solid against the manifold somehow, perhaps with a second block of wood. If I were to depend on a helper for anything in the garage, it would be a scheduled event.
If you zip tie or clamp or hold the wrenches near each other then hitting one with a hitting object should get the impact decently.
would a warm compress (i.e. warming up the outside as fast as possible without warming the inner fitting) help too?
Also, longer wrenches (better lever arm). Would a crow foot with a breaker bar get you that longer lever?
Lol. I do this by myself. I have three arms.
