How would I clean out the cabin air intake?
AGraham
I was upside down in the driver's side foot-well with a brake pedal in my right eye socket and a flashlight between my teeth yesterday going to war with the heater control valve when, who'd of guessed it, fall came early! Leaves, needles, grass clippings, detritus galore. The entire central tunnel under the blower and exchangers was PACKED; there was a fair amount of moisture under the driver's side carpet as well; thankfully, no rust.
How does one clean out the intake under the windshield bonnet/cowling? Furthermore, has anyone figured out a mod to stop crap from building up in there? Perhaps screening or modified snow-caps would do.
*'92 240 Sedan*
A leaf blower pointed at the cowl with a shop vac sucking stuff out through the rocker holes and floor vent holes is probably the most effective way to clean debris out of that area. Even if you pull the heater box you still don't get full access to the inside of the cowl since there's still some non-removable sheet metal there.
Flexible air hose nozzle, you can get a pretty good access through the wiper motor hole
Next is where the a pillar kick panel vents would go, after that it’s the rocker panel access holes
Well, this is sounding more and more like a surgical operation. I suppose I could cut an access port in the top of the firewall, just above where all the cables are strapped; use some weather strip and maybe a magnet to cover it back up after cleaning.
I sincerely feel bad for anyone who has one of these cars parked under an oak tree.
No that’s a dumb idea
Oh, it's incredibly dumb, and entirely lacks refinement. Alas, there is no way those vents aren't going to continue to suck up crap; so being able to clean it regularly would be nice. For the moment, there is a nice wad of Spanish moss blocking the hole, the cabin air filter Volvo deigned not to give us.
20260927_170130.jpgOkay, better plan: don't cut the firewall; cut the cowling itself right behind where the weather strip already sits.
Snow caps keeps the stuff out in the first place.
Compressed air, especially if you get it in a small flexible hose that will go into the cowl vents and let it "wacky-used-car-inflatable-arm-wavey-guy" to stir up the schmutz. Then put a shop vac in the access ports inside the kick panels. There are some rubber body plugfs in there that are big enough for a shop vac hose. Using both at the same time migrate the junk into the bottom of the rocker where the shop vac sucks it out.
There will be a lot more crap in there than what you can see.
Removing the cowling is pretty easy. That will give you access to the blower motor from the top. A good shop vac will get most of it.
I'll give this a try. It sounds admittedly better, if not less exhilarating, than my back up plan to pour sulphuric acid into the cowling and run the blower on high.
I usually pour some old gasoline in there light a match and throw it in and just burn all that crap right out…..
No don’t do that - compressed air, shop vac, more compressed air and so on and so on till it’s clean
