gear whine
advocate of k-jet
- Dec 17, 2006
- 18452, NEPA
91 740 B230FT m46 w/ hydraulic clutch
ok lets be frank here
driving to work everything fine, all of a sudden, no clutch.
a day later or so at work i pumped the pedal and saw fluid leaking out past the little U-seal in the slave cylinder.
i figured, oh cool its just that. ill pop that out and throw another one in.
ordered one from fcp got it the next day(today) and proceded to put it in after work. got it in and started to bleed the system. built up a bit if pressure but ONLY at the very end of the pedal travel. built it up a bit more and it got stiff for a couple presses and then it went away WITHOUT touching the bleeder screw.
i figured, ok, there is still air in the system we need to bleed it more. pumped it up, cracked the bleeder, pumped it up again a fluid SHOT out of the same U-seal out of the BRAND NEW one i just put in.
BTW the fluid level in the master cylinder resov. was checked and full the whole time.
ANY IDEAS?
clutch master cylinder?
this system seems pretty basic i dont know how it blew the seal out of the new slave cylinder
please help, urgent...need to get car drivable again asap, its my daily
volvo techs?
thanks ANYONE for help.
ANY IDEAS?
volvo techs?
