2turbotoys
Have you seen me?
- Nov 13, 2007
- Reading pa
Feel free to use my info from the other thread, I can transfer it here but don't feel like typing it all again.
Thanks, updated!Feel free to use my info from the other thread, I can transfer it here but don't feel like typing it all again.
316s fit behind Geminis. MBK not BBK
I wonder how the 17Z calipers compare to the Cadillac ATS brembos dimension-wise. 6 pot vs 4 pot might save me a little space. Was planning on running RC090's with 25mm spacers and these ATS BrembosGood News and Bad News.....
We'll start with the Bad news first...
BBS Style 5's aka RC090 - DO NOT FIT.
Above is fitted with a 20mm adapter, making them effectively 17x8 +0 this is about as far as you can go and still keep the wheel under the fender (without significant camber)
Not that that even matters....
Just for fun I tried with a 25mm adapter (17x8 et -5) to at least give the spokes a chance to clear
Ok, spokes barely clear..... but wait, there's more!
ATS Brembos are more similar to V70R/S60R Brembos, than they are to 17z's (hence why they are the focus of this thread. Basically any wheel that fits 17z will fit any BBK you slap on a 240 ....within reason). So I think you will be fine with RC090's+ ATS brakes.I wonder how the 17Z calipers compare to the Cadillac ATS brembos dimension-wise. 6 pot vs 4 pot might save me a little space. Was planning on running RC090's with 25mm spacers and these ATS Brembos
I hope so!ATS Brembos are more similar to V70R/S60R Brembos, than they are to 17z's (hence why they are the focus of this thread. Basically any wheel that fits 17z will fit any BBK you slap on a 240 ....within reason). So I think you will be fine with RC090's+ ATS brakes.
I too had dreams of running RC090's (actually style 19's which are the same barrels but different faces) but I'm glad I went with my gut and sold them, or I'd be wheel shopping with my car on jack stands .....
*Upon closer inspection RC090's are actually a pretty awful design from a fitment standpoint, a very inefficient use of space, even compared to other 17" multi-piece wheels.
Are you saying that the wilwood brakes will fit a virgo wheel with at leat 15mm of spacer or are you talking about the R brakes. I have been eyeing both but I'm not quite ready for new wheels yet, i'm currently on virgos with 25mm spacer, If you know what would fit under that setup please let me know!lol. Theres a lot more to brakes then just diameter…
Yes it’s smaller than R brakes, but it’s more appropriately sized for the system. R brakes do work, but they really throw the brake balance off in the car and when driven hard on track you’re going to find that out really quickly. They also don’t fit Virgo’s, but they will clear a Motorsports designed 15” wheel with the smaller rotor option. Edit: They will fit virgos with a ~15mm spacer.
Sure, they’re not as big as a set of R brakes, but they’re exactly what’s needed for road racing and rally. So if you think you need more brakes than that, go ahead and get R brakes.
They might fit a Virgo with a 25mm spacer, I can check.Are you saying that the wilwood brakes will fit a virgo wheel with at leat 15mm of spacer or are you talking about the R brakes. I have been eyeing both but I'm not quite ready for new wheels yet, i'm currently on virgos with 25mm spacer, If you know what would fit under that setup please let me know!
That sucks :/ My brother has a set of bmw m parallel wheels I can put on. I don’t really know if using a bolt pattern adapter would take away any clearance Id have left without rolling my fenders a lot and taking out the wheel liners lolThey might fit a Virgo with a 25mm spacer, I can check.
The Virgo is the hardest OE 15” to fit around bigger brakes due to where the drop center is on the barrel… right where the caliper is. Stupid reverse mount wheels.
Please let me know if you figure out if they fitThey might fit a Virgo with a 25mm spacer, I can check.
Coming back to this thread, with the 17Z and style 5 combo, already planning on running 25mm adapters, what all on the caliper needs to be clearanced?Good News....
BBS RX 239 Fit! 18x8 +40 (30mm adapters)
Porsche 17z BBK
225/40/18
Front fenders untouched
Rear fender lips trimmed / folded
They don't fit.Coming back to this thread, with the 17Z and style 5 combo, already planning on running 25mm adapters, what all on the caliper needs to be clearanced?
