Idle issues and stalling after coasting
Coles91F+T
Hi guys, first post here. I have a 1991 240 B230F+T, I have some idle issues every now and then and a stalling after coasting down the highway that I can replicate pretty much 100% of the time. It doesn’t happen when coasting from slower speeds. Only the highway speeds and it happens when I come home and go to the gym. When I come to a stop it will live for like half a second and then just die. It then will not turn on for like 5-10 minutes but after it feels like it, it will just start again. Wobbly idle but it’ll come back to normal. I’ve confirmed it’s not the IAC, I don’t think it’s my MAF as it’s quite new. I’m wondering if it could be some overheating electronic? But which could it be? And why only after high speed coasting to a stop? Thank you guys and I look forward to hearing your input.
When you say it won't turn on for 5-10 mins after a hot stall, do you mean won't crank or won't catch and stay running? I'd be suspicious of your fuel pump relay (white relay, behind the glovebox). As it's an intermittent problem it may be worth opening up the relay and re-flowing the main solder joints to see if that fixes it before getting involved with a proper diagnosis.
It. Won’t catch and stay running. Sometimes it sounds like it might catch but doesn’t, and then sometimes it’s just crank and won’t catch at all. I have heard of that fuel pump relay being an issue but I was told by the previous owner it was brand new silver one. But I suppose it could still fail, I’ll have a look tomorrow. I’ve got a couple extra relays of my own so I’ll try them out.
So this was my fuel relay. It is not the silver one as I thought, so maybe upgrading to that would be smart. But it wasn’t super hot. I could hold it and it was definitely warm and if I held my hand on some of the contacts to long it did start to burn. But it looks very clean. Should I rule this out?
IMG_3098.jpegIMG_3098.jpegIMG_3101.jpegIMG_3099.jpegIMG_3098.jpegIMG_3101.jpegIMG_3099.jpegIMG_3102.jpegIMG_3100.jpeg
Nope, a warm (but not hot) relay is normal, but you can still have poor connections at the solder joints. Initially this may happen after a period of extensive running, but will soon be followed by total failure of the relay. Grab a decent soldering iron and reflow all the main solder joints on the pcb board. Adding a little solder can make for a better heat sink, but don't allow a solder bridge to happen. I'd say the odds are 50/50 that will fix it.
It’s been a couple days and with some light troubleshooting in the dark I might’ve found the problem. Wondering what you guys may think of it. Shown in the photo is my radio suppression relay, and to a solder noob like me, they look like they've been subject of some pretty bad expansion.
Do you think I've hit the money? I didn't even know this controlled the injectors till now so I never suspected it once. 1793489058479.png
I've seen worse, so may or may not be the problem. Will only take you a few minutes with a soldering iron to reflow all those joints. Do both relays and scrub clean with isopropanol contact cleaner when you're done then slap them back in and see if that helps. Too bad it's not a 940 as the electric fan relay is the same as the RSR and can be swapped in for testing . If reflowing it doesn't help then the relay may be gone. You can easily use a diagnostic test at the OBD system socket to verify if the injectors can be pulsed by the RSR relay. See DTM3 in the OBD section of the 700/900 FAQ (same LH 2.4 system) here at https://www.volvoclub.org.uk/faq/EngineOBDCodes.html#FuelInjectionandIgnitionDiagnosticCodesi
