Smokey77
- Jun 9, 2024
- Goodyear Arizona
This is on a 92 940 regina car.
So I made the mistake of messing with the idle linkage rod thinking that that is where I adjust the idle, I wanted to bump up the idle in order to prevent it from stalling whenever I came to a stop, only to see the idle adjustment screw right in behind it. Now here is my problem, when I first start the car it idles low, put it in gear and it wants to stall but will stay running at pretty much below 100rpm. Not good. Put it back into park and tap the gas to get it back running, now it idles around 1000rpm with the ac on. Turn off the ac and it surges between 1300 and 2000. Clearly I messed up big time here. I set it to a point where it is driveable. I see there is a way to adjust it, but it is a writeup for an LH/Bosch system. Not sure if it is any different for the regina cars or not.
Upside is that I don't stall when I pull to a stop anymore. Downside is I am ready to drive this thing off a cliff, especially when mechanics down here apparently don't know how to mess with OBD1 cars.
