If the alternator is weak... is it normal for the Alt light and Brake System malfunction light to display?
Thoragaverung
Minnesota
Hi, I'm wondering about the behavior of the Brake warnng light.
If the alternator is weak... is it normal for the Alt light and Brake malfunction light to display? I know the Alt light should, does it trigger the Brake light also?
Thanks
1990 Volvo 240
Alternator on order
If you turn the key to Run without starting the engine you should see most or all of the warning lights come on.
These same lights should go out once the alternator starts charging the battery. An alternator or alternator belt failure will turn them all on again.
I don't remember about the brake failure light specifically.
It is that way on my old BMW, failing alternator will illuminate battery warning light and brake warning light, both...
I had the very memorable experience of losing both the alternator belts while descending the pass into Cali... All lights on and the engine starts overheating all at the same time. Not fun!
Several things to be checking in regards to the charging system:
Alternator
- If the alternator is going bad such as a bad diode or slipping belts, then the battery warning light should illuminate as it is not outputting at least 12V.
- Wiring or grounding issues can lead to the alternator not charging due to it not reaching an excited state. Revving the engine to around 3K RPM can trigger the exciter to start the alternator charging.
Battery
- If the battery is reaching end of life or discharged, when starting the car there can be a shrieking noise from the alternator. This happens when the alternator is put under a heavy load from a low or weak battery.
- If the battery isn't properly charging while the engine is running, will sometime see the Check Engine light illuminate. Have experienced this when the engine is running/idling, but barely due to a vacuum leak, misfire or bad ignition wire(s). It will not stay one (thrown a code) but I see this as a leading indicator of a voltage drop.
Voltage Regulator (mounted into the 240 alternators)
- When the brushes are wearing/worn out these will sometimes cause some of the warning lights to glow. This may show up when there is a large electrical load on the system (driving with the headlights on) or have seen the battery light dimly happen when cruising at highway speeds at 3500 RPM.
- Conversely I've had a voltage regulator's electronics go bad and this resulted in the alternator suddenly putting out 18-19V. This will quickly burn out light bulbs and other electrical items.
I would suggest narrowing things down to see where your the issue is originating from of one of these three areas. If you have a multimeter, what is battery volt level at rest (more than 12.6V) and when the car is running (more than 13.5V). If you don't have a mulitmeter, then highly suggest getting an inexpensive cigarette lighter USB charger with a voltage display.
So yesterday when the lights illumined it was after first start-up after replacing the fuel injectors. Idle seemed OK, but the lights were on. Voltage was at 11.5 according to my cigarette lighter voltmeter. I revved the engine a couple of times and voltage popped up to 13.8, and the lights went out.
Exciter? Voltage regulator? Anyways, the new alternator is on its way from Rockauto...
The engine needing a little blip to get the alternator light to go out is pretty normal, especially if you just changed a critical engine component and the idle was a little low for a moment. It doesn't point to a failed alternator.
The brake failure, parking brake, and alternator idiot lights are all powered by the exciter wire. When you have an alternator issue it's common for all 3 to be dimly lit. A broken exciter wire will not allow those 3 lights to light up.
Also here's a hack: the brush pack/voltage regulator/commutator whatever you want to call it is $15 or so and the culprit for most alternator failures. I would not replace an alternator with good bearings for an autoparts store reman.
Another 240-failing-alternator-thread!
Voltage drop test the negative side.
Make sure the exciter wire isn't shorting out/failing under the front of the old greasy engine.
Pull and inspect the brushes.
I've had experienced a couple symptoms of the lights being dimly lit. Usually the voltage regulator in both instances. Once the lights were always dimly on with the headlights and would get slightly brighter as you rev but never fully lit. The other instance was dimly lit all the time. This can happen from a voltage differential between the B+ and D+ terminals. The voltages on those terminals should be the same. If the voltages is lower on the D+ compared to B+. Then the dash lights will come on dimly.
