Jamesmoore
- Jul 26, 2021
- united kingdom
Hi
I’m trying to run these injector adapters
With these Injectors :
www.speedingparts.co.uk
However I’m running into an issue with the fitment of the adapter.
The internal diameter of the adapter measures 13.7mm and the outside diameter of the bottom injector seal measures at 14.5mm. The adapter will not fit over the seal, it will damage the seal if I force it.
What is the solution here ? The stock o ring measures at 14.5mm OD x 8.5mm ID and 3.5mm thick.
The closest off the shelf seal I can find is 14mm OD X 8mm ID and 3mm thick. Would this work ?
I guess the slightly thinner seal would be ok but it would be fairly loose in the adapter, I believe 0.5mm is the ideally squash on an o ring I’d be at 0.7mm, doesn’t sound a lot but high pressure petrol isn’t something I’d want to leak out or blow a seal.
Any advise
Cheers
Bosch injector 630cc
Bosch 630cc Injector Mounted OEM on the following car modelsPorsche 997 3,6 GT2 530HP 07-12Porsche 997 3,6 GT2 RS 620HP 10-12Porsche 3,6 Turbo 480HP 06-09 Name: Bosch 630ccPart number: 0280158123 / 0280 158 123 / Bosch -123OEM number:997 605 132 00997 605 132 01997 605 132 02Package...
Any advise
Cheers
