Epic2112
- Sep 29, 2007
- Silver Spring, MD
Is it safe to lift the rear of the car from the diff? Is there a better place to lift the rear of the car from if I'm doing work on the rear end?
i don't believe in chocking the wheels if you are on a level surface. The car rolls alot easier than the jack, and one of them has to move when raising the car. So i pick the car. Otherwise alot of force gets transferred horizontally between the jack and the car, possibly resulting in the jack tipping or the pad slipping off.
I don't believe in chocking the wheels if you are on a level surface. The car rolls alot easier than the jack, and one of them has to move when raising the car. So I pick the car. Otherwise alot of force gets transferred horizontally between the jack and the car, possibly resulting in the jack tipping or the pad slipping off.
To whoever was worried about all the weight going on the drain plug, I'd suggest sliding the jack back a bit so that the center ridge of the diff is sitting in the cup. If you go forward with the jack the slope of the diff can cause the jack to slide forward or to the side.
Meaning the cup sits on the ridge were the back flange attaches?
Use a 3/4" plywood square or 2x4 block to distribute the weight.Jacked my 240 up today by the diff today when I changed the rear diff oil and a brake fluid flush. My only concern is when you jack these cars up using the diff, you are actually putting the jack on the diff drain plug. all the weight of the whole car is on that bolt! Next time I will slide the trans jack a little further toward the front of the car/diff.
