bogmire
- Oct 13, 2025
- Eastern Iowa
Well, removing the fuel sending unit only took all weekend...
The trunk has been the storage spot for all the removed parts so far, so step one was to empty the trunk. Peeled back the carpet trim panels, opened up the access hatch, and assessed the situation. Rusty, rusty, oh so incredibly rusty hose clamps. Luckily, all the clamps on the sending unit hoses came off without much drama. The first struggle came with the little hose that branches off the big filler hose, and attaches to the gas tank;
Absolutely no chance at getting a T25 on top of that clamp. Must've been installed with the tank removed from the car. Grabbed the hack saw, gently cut through the bolt, and carried on. There was one last clamp that I needed to remove, holding the filler hose to the trunk side tube. Grab a socket, some extensions, climb under the car aaaaand;
Snap the head of the clamp screw smoooove off. Great. Grab the hacksaw, realize there is no room for the whole saw, remove the blade and get to work. Slowly cutting through the screw band of the clamp, whacking my hand on the parking brake cable and panhard bar the whole time. Eventually, I liberated what was left of the clamp;
With all the hoses removed, I could finally remove the sending unit. Locking ring came off easy, gently pried the unit out of the seal, and was left with the task of twistifying the sending unit out of it's home. I was following along with a guide/video, both of which explained that the sending unit needed to be twisted counter clockwise to get the barrel up and out of the baffles. That didn't work for me, no matter what combination of angles and spins I threw at it. Eventually I stumbled upon a different write up, stating that the unit should be pulled under the floor, then spun clockwise. That was the ticket;
Looks like I'm not the first one to be oogling this thing. Makes sense, seeing as there were some witness marks on the lock ring. Got right to eyeballing a spot for my wire bulkhead, it looks like this;
Nice way to pass some 12 AWG Teflon insulated wire through. The last issue is the fuel pump itself, as it's a smaller diameter than the original;
Crappy picture, but the DW200 is a hot dog, and the basket is a hallway. Soon as I come up with a way to fill that space, or some other way to mount the pump, it'll be ready for re-install. This time, with stainless hose clamps.
