Justin's Manual Swapped 960 Wagon
Do you know off the top of your head the two wires for the reverse lights?
That'll be pin 1 & 2 on B5
Update: have you seen this?
Seems like a great solution to the diff ratio issue. 3.15 is what the manual e46 comes with. i will probably order soon enough.
5 speed (ZF) is 1:1 5th. M90 has an overdrive 5th. I wouldn't want a 3.15. My E34 M5 had a 1:1 4th and overdrive 5th and was 3.91:1.
Edit: I just realized the op chose to not use the gearbox that would bolt right up.
Finally got the Tenaci 3.15 gears installed. This was my first time messing with a differential so it was a long journey.
Diff came out no problem. Just about every suspension bolt has to be loosened. The differential is sandwiched between two big cast aluminum pieces.
After pulling the old gears I noticed that the threads of the pinion are smaller on the new gear. The splines on the shaft are also higher. This will require a different nut & a spacer.
I had to pull the old bearing off of the pinion. The shim below the bearing has to be re-used. Pulling the bearing was a real battle. Had to grind & chisel the bearing race.
Installed the shim & a new bearing on the pinion. Also installed a new pinion seal.
Pulled the gov lock apart to cut the flyweight off. This should keep the diff locked at higher wheel speeds.
Wound up having to make a 1/4" spacer to clear the splines on the pinon. I bought this Mazda Miata axle nut to fit the smaller threads on the pinion. Wound up having to machine the face down to clear the driveshaft.
Got everything roughly assembled to check the pattern on the new gears. Gear marking paste is expensive so I used some acrylic paint here. Looks like I got real lucky. Didn't have to mess with any shims & the pattern looks acceptable to my untrained eye. Followed some guides for dana 30 differentials for the pinion drag. Had to re-use the crush sleeve as I couldn't find any new ones.
Ready to go back in the car.
I've got about 100 miles on the new gears so far. No scary noises yet. The new gear ratios make this much more drive-able on the highway. 5th gear 3000rpm is 70mph now as opposed to 60mph before.
Wow! That is much higher RPM than I would have expected.... the BMW gearbox you used (or was it Mercedes?) must have been a real stump puller if those are the highway gears. What was the original final gearing, something like 2.56 to 1 or lower?
I would have hoped for the white block turning around 2300rpms at cruising highway speeds like 70 mph.
Yep, E36 BMW. Those had gears ranging from 2.93 to 3.15.
Funny coincidence, this gearing actually lands me very close to where an M90H would have been on my stock diff.
Got a bunch of small things done on the 960.
Found that my new A/C compressor was leaking from the front seal :mad:. I replaced the compressor & put a new standard orifice tube in. The automatically adjusting orifice tube that I originally put in there made a bunch of whining noises after the A/C was turned off.
I pulled the rear hatch interior apart to install the 3rd row seatbelts. This was a combination of parts from DET17, supreme940, & the junkyard. Also fixed the tailgate interior trim with these 3d printed parts.
Lastly, I've been wanting an egg crate grille for my 960. I recently got to borrow a Bambu H2D printer that was big enough to print a grille in two halves. I 3d scanned the old grill & modeled up an egg crate grill to print.
Did most of the surface modeling in Fusion 360 & did some touch ups in blender.
The first prototype print. The two halves are bolted together.
I did the final print in ASA. Really happy with how it looks!
I really like this and would like to give you money for one
Hey! Can i have picture of how the drivehsaft fitting on your's? I'm putting a getrag 260 on mine but i have problem with driveshaft, the second part is easy to do, but the front part even the manual one is too short to get to the support plate
Thanks guys! Hopefully some engine mods soon! I'd really like to get this on a standalone ECU.
I forgot to get some photos of the driveshaft before I put it in. I used a Z3 driveshaft for the front & I just had to drill some holes in the driveshaft mounting plate for the bearing. What BMW driveshaft parts are you using?
There's more info on the driveshaft setup in this post: https://turbobricks.com/index.php?threads/justins-manual-swapped-960-wagon.377486/post-6484012
Is it a no on the grill?
I have a getrag 260 from a e30 and the guibo is smaller than the other getrag, i have the strongest gearbox but also the rarest, ive tried a auto drivehsaft too short niw i've order a manual drivehsaft, crossing my finger hoping it fit
We have a deal worked out to print these for you all, will send a photo soon. Same pristine quality you know and love ;)
Best way to get in touch is PM here or Facebook (VPrints).
Price is $105 plus shipping. These grilles are chunky.
