Ashtong180
- Feb 13, 2023
- Portland, OR
TL
R: car won’t hold an idle out of nowhere, presumed timing belt is off/ vacuum leak???
After owning my 85’ GLT turbo 245 for about 3 months, I’ve gotten used to its many quirks, one of the more persistent and concerning being the rough idle along with the late shifting. I was driving about 100 miles from Portland to Redmond and almost 20 miles away from our destination, my car stalled(auto) while cruising and would it start up. It would crank and crank and I could get it to idle (even more rough than before) if I were holding the throttle open and it definitely looks like what’s left of my motor mounts are kaput… luckily this was right after the 20+ miles of no service and being off the side of a huuuge valley, I couldn’t imagine if my car stalled and I couldn’t use my power brakes out there I am so grateful it broke down the second I got into a tiny little town. Thankfully as well I broke down in between the only dealership and auto parts store down there and got as much help as possible from some nice people. I checked the first of my suspicions for a long time running which would be the IAC and throttle body being clogged up, opened it up, clean as a whistle?? Checked fuel pump pressure, perfect. Checked spark, intake, vacuum leaks, and a bunch of other things I couldn’t name.. even checked the timing belt which was running a little higher (between 10-15 I believe?) but I shrugged it off due to be having to rev it to keep it alive… after hours of nothing, I unplug some sort of connecter that plugs into the IAC or what I believe to be the IAC that goes into the throttle body, and when unplugging that connecter, it decides it wants to idle, not for long or very well but it at least idles. Entire block is shaking all over the place. So I call a mechanic that has an open phone line today and tell them everything and they suspect it is the timing belt, and/or a vacuum leak which I thought we had crossed off the list… great. Any help is greatly appreciated. Because now my (only) car is 80 miles away from me and I won’t be able to tow it back and take it to a shop (if i even have the money) until Tuesday… thank you for reading!!!
