Hi everyone.
The R-Sport gauges (image below) for 240 and 140 had been out of production for a very long time. A used set cost more than 1500USD now. The old style cable driven speedometer also doesn't fit the later car with VSS. Most of the people with 240 today have a LH2.4 or converted to LH2.4. The old R-Sport gauges won't meet today's demand anymore.
Here is the KICKSTART project for reproduction the old R-Sport gauges.
I'm trying to find a manufacturer and Replicate the R-Sport gauges with modern technology but the same look.
Gauges to be replicated:
Bracket that fit the 85+ 240
Speedometer (will read VSS, or receiving signal from GPS, let me know in comments.)
Tachometer (will read crank sensor signal as it used to be)
Temperature gauge ( for both water and oil)
Oil pressure gauge ( compatible with VDO sender unit)
Turbo gauge (vacuum line or digital sensor, let me know in comments)
Fuel level gauge (read from stock sender)
Voltage gauge
Ambient temperature gauge
Any other gauge you want to add to this project please let me know.
Gauge technology
Analog?
Digital?
The warning lights and turn indicator.
Fits 86+ (or more? not sure if possible, please comment)
I want to add a set separate turn indicator instead of the old R-Sport gauge using only one indicator light.
Wiring and connector.
Fit 86+ (or more? let me know if this is possible)
Lighting
Back light like modern gauges or side light illumination like the old ones.
I would prefer the back light.
Needle color
Glowing red?
Silver?
The gauge will be in standalone units and could be install separately into 240 gauge pod.
Do we want to make the gauge face changeable?
Do want to add any dual gauge (image show below) for more information can be shown in the 240 limited gauge pods?
How likely you would buy a set if this successfully go in production?
Would you join this project if it's published on Crowdfunding platform?
Please let me know what you think.
You are welcome to upload gauge face design here.
Voltage gauge
Gauge technology
Analog?
Digital?
Lighting
Needle color
Glowing red?
Silver?
