FastBrick10
- Jan 16, 2025
So here is the rundown we have a 93 240 we did a plus T conversion and its running on a microsquirt. It starts, idles, and will happily rev in neutral. When placed under load its down on power and wont rev out. We have been able to drive it with this issue but sometimes it just has no power and you can't even get out of first gear. Speaks to me like a fuel issue of some kind but the AFR readings are solid. We changed the fuel filter, FPR, and the high pressure pump. Did a pressure test at the rail and were reading 41psi at idle. Did a injector test and injectors were all spraying good. Timing has been checked and is right. I would post a datalog but the file type is not supported.
Symptoms:
Down on power
Will not rev out under load
Sometimes just refuses to even get out of first
Setup:
B230+T
Td04 19t on stock wastegate pressure
IPD turbo cam
30lb/hr injectors
Stock fuel system
Symptoms:
Down on power
Setup:
B230+T
IPD turbo cam
30lb/hr injectors
Stock fuel system
