RAPTOR479
- Jul 15, 2022
- Revere, MA
As somebody with an LH3.1 240 ive long read that it is an inferior system for any sort of modification to LH2.4 because of the low ceiling of the early stock hot film MAF volvo used, even to the point that a cam swap could make enough of a difference to be above the ceiling of what the original maf is capable of reading. Of course M cams are for losers and even before I had my driver's license I shoved an A cam from a boat engine in my car, this seemed to work okay until the stock maf mysteriously failed somewhere around 5000rpm leaving a service plaza merging back onto the highway in 2023, since then I have had a mystery aftermarket maf and now a Delphi replacement from Rockauto in the car and changed to a VX3 cam, in the probably 35,000 miles now of driving the car I've never noticed a hesitation at high rpm outside of what youd expect from a car making 100whp. I dont have the ability to test mafs or look inside an LH3.1 ecu so my question is if anyone knows or can test if whatever off the shelf (i assume) parts are in the new replacement mafs are capable of reading more airflow and thus raise the performance ceiling of the entire system, ive never had issues with the LH3.1 in my car and the 850 shared tps and brand new $90 maf sensor that works fine (things LH2.4 owners can only dream of) are sure handy
