- Oct 1, 2019
- Mississauga, ON (Canada)
I'm going to do some more reading on this.The early 960 used smaller sprockets, the same size as a 5 cylinder. The 95+ ones used larger sprockets and a much wider belt, which carried over to the RN/P2 engines. The water pump pulley size also changed.
I think that's part of the reason they had such a low interval early on. Too small of a belt drive.
AFAIK, you can take the crank sprocket, cam sprockets and water pump for a late 960 and bolt them up with the wide later belt.
I'm hoping it's possible to just get the updated sprockets from a late P80 or early P2 car - those are very available at the scrappers right now. Then it would just be a matter of buying the "late" timing kit which already has the updated pump, wide belts etc.
I do a lot of panicking about belts but not a whole lot of driving - I don't think I've even put a full 10,000 miles on my daily 940 since I changed its belt last October
