Just do it!!! Best upgrade that I have made and experienced so far....You DO Want to do the 3rd Gear Sychro Welding mod to further beef up the Stop Ring so a Missed Shift doesnt leave you stranded...I refreshened with New Input Shaft Bearing, New Seals, 3rd Gear Stop Ring Mod as well as New Hardware on the shift linkage, hydraulic pedal linkage(I bought Steel Clutch pedal) and new slave and master cylinders...You pretty much want to go over the Gearbox and associated pieces, including front prop shaft rubber and driveshaft rubber and mounts...I replaced u-joints as well while I was "In there"....Whatever it takes to make it a 1 Fingerprints Affair...
