Go to page 9-10 on this thread. Nästan allt finns der.Can anyone help me with instaling my maxx ecu mini on my volvo 940 b230 fk 96 i have some mods like t3t4 turbo and a set of bosh injectors (gröna R spridare) thats the name in swedish and I need to know what sensors and stuff i need fore the instalation of the ecu
I'm interested to know about the VSS wiring also.Has anyone documented the relay stuff for a Volvo 940 getting the RPM gauge to work with pullup? and.. does the VSS signal from the rearaxle go directly into VSS input?
I'll take a look tomorrow. When you say RPM gauge, you mean Tach or Tachometer for us US folks? The 240 tachometers may work with a pullup, or may need a cube relay with the flapper removed, to convert the ECU tach signal to one that works with the gauge. I'll see if I can find what the 940 tachs need for a signal.Has anyone documented the relay stuff for a Volvo 940 getting the RPM gauge to work with pullup? and.. does the VSS signal from the rearaxle go directly into VSS input?
The VSS signal needs to be the one off the speedometer, not the raw signal from the rear axle. You'll need to find the VSS wire that went from the 940 speedo to the LH2.4 ECU.
As far as I can tell, all the MaxxECUs need a digital (or hall) signal for the VSS and wheel speed sensors. They do offer a VR to Hall (digital) conversion board, which will be needed if you eliminate the original Volvo speedometer (the original speedo does the VR to hall conversion). When connecting to the original speedo-to-LH2.4 VSS signal, you'll need to enable the pullup on the MaxxECU input, or use an external pullup resistor, 1K ohms to +5Vref.
VR to hall sensor converter (VR2DIN) board 2-channel DIY - MaxxECU
Motorsportprodukter - VR to hall sensor converter (VR2DIN) board 2-channel DIY - MaxxECUmaxxecu.com
See youre inbox ! i have taken a 4 pin relay. i cut away the plate between terminal 30 and 87 . i took the orginal wires for the tacho.Has anyone documented the relay stuff for a Volvo 940 getting the RPM gauge to work with pullup? and.. does the VSS signal from the rearaxle go directly into VSS input?
if duty cycle goes 100% and no change in pressure, then you have wastegate hoses wrong, or its an inverted outputI’m having trouble with the boost control. It works fine in open loop and it has been for a while now. But because of big temp changes outside, I want to set up closed loop with a target pressure.
But whatever I do, it doesn’t go above wastegate pressure in closed loop mode.
Does anyone know a fix for this?
Cheers
tacho output has enough booty to push the 240 tacho on its ownHas anyone documented the relay stuff for a Volvo 940 getting the RPM gauge to work with pullup? and.. does the VSS signal from the rearaxle go directly into VSS input?
OEM cluster takes the diff signal and conditions to a squarewave. you can take that squarewave signal and pipe to any DIN.I'm interested to know about the VSS wiring also.
Race Unit W LSU 4.9 kitHello,
I have a b21ft / Kjet car.
It has EFI fuel pumps done by previous owner.
I dont have any trigger wheel or injectors etc bought yet.
Considering MaxxEcu Sport or Race.
My goal will be ~350 HP in time, but that will have to be after new trans, turbo, ic, etc.
But considering longterm goal I should then buy:
stage 0:
* Good FMIC
* Injectors with enough headroom for ~350hp
* Sparkplugs with r for EFI
* Some sort of triggering system (Yoshifab CAS, or lh2.2?)
* Some sort of coil(s), WS or not... I guess for my goals a WS coil is plenty good enough?
* IAT sensor
* CLT sensor
* TPS sensor from 850/960 w/ adapter for lh2.4 throttlebody OR> ethrottle if I do sport/race (then I wont need idle valve)
* Electronic boost control
* Knock sensor? should I add one? maybe so, but saw some videos about tuning a knocksensor is hard?
I guess Sport would be more than enough for my goals, but when I look at sport package with lambda, the price hike to race isnt "crazy".
So what are you guys suggestions about triggering system, I kindof dont want to use money in wrong places.
Additional notes
I am working on swan neck intake with lh2.4 throttle body, I have also bought an F intake which gives me a fuel rail I can use for the injectors fitted in the head. Do know it has to be modified a bit to mount towards head in the kjet tapped holes for injector holders.
