HiSPL
Fanking Champion 1993
- Jan 8, 2015
- College Station, TX
I have a persistant miss that happens every now and then which I believe only happens when the engine is hot and the E-fan is running. I have the OG 80 amp Bosch alternator, but when watching my voltage in TS it never goes below 12.7. The voltage, however never fully goes to 14.4 while driving (measured by the ECU) but is in the 13's.
What could I look at to start chasing this down? Is it an interference issue with the fan running? I'm not showing any sync loss.
Is it just low voltage/too heavy a draw to run the fan?
Old Coil/low voltage situation? It's the OG bosch/distributor setup my car always had (1988, LH2.2, Chrysler-ectomy).
Where should I start poking this bear?
Car is an 88 244. Microquirt conversion. Original coil and distributor. Using the Original hall sensor in the the Distributor. No crank/cam sensor.
