rb92673
racecar
- Jan 17, 2017
- San Clemente
Thanks!
This is great, did you have to reprogram the abs unit to work well in the Volvo?
A very common swap for BMW E30s (which incidentally also used ABS-II) is the Teves MK60 as fitted to the E46 (2001+) M3. Actually, this unit is a common swap into many platforms, as it runs standalone and can be flashed with some fairly interesting software. Even stock, however, it's a much better, smarter unit.
Actually only came in the 2003.5+ (LCI) e46m3 cars. The earlier cars all had the MK20 system.
There are three ATE part numbers for the MK60 on e46m3s:
ATE 10.0960-813.3
ATE 10.0960-818.3
ATE 10.0960-817.3
Do you know why you can't just use the ABS system from a regular non M3 E46? Were the other E46s MK20 regardless of year or is there some other issue I'm not seeing?
If this is just being used to control ABS, do things like the M-track mode, etc... make a difference at all?
Seems like if you wanted stability control it would be more important?
To add stability control you need a steering angle sensor, and connection with the ECU to cut throttle at minimum.
The non-m MK60s have different programming and different part numbers from the m3 units. Although they physically look the same. I don't know if there are any internal differences between the non-m and m3 systems other than the programming. They do have the same plug ends though.
With that said - all units can be programmed (to a degree) using the BMW INPA software. You can program a non-m MK60 system with all the m3 zcp/csl settings and vice versa. A lot of these settings have to do with the fact that the M3 has an LSD while the non-m models (325/330s etc) had an open diff and different brake sizes (piston area etc).
> The CSL settings raise the slip and yaw thresholds above the stock programming. It also adds M-Track mode for users with an E46 M3/330i without the ZCP package.
Have you tried using this system as stability control or as an electronic limited slip? At our last Sonoma race it rained all weekend and the E46s were very fast in the rain.Afaik all E46 hydraulic units are the same, but the brain is different. We're running an M3 brain on the 330i valvebody and it seems to work perfect. Did a full endurance race weekend (in the rain/damp/dry mix, ~14h running) on it like that without issue.
You can sort of turn the non-M unit in to a CSL, but not quite. You can change some of the stability control limits and tell it you have an LSD, but there is no way to get the more aggressive ABS tuning from the M3 without an actual M3 module. You can turn any M3 module in to a CSL, though. We've run both the 330i brain and CSL-ified M3 brain, and the M3 does a better job of ABS.
I found some training guide, it looks like it is speed limited at 24 mph in regular mode and 42 mph if you hit the DSC switch. Probably not very useful on track. More like a G80.As far as I know the mk60 doesn't do eLSD, it just has an option to tell it there's a mechanical LSD present so it changes the stability control/ABS algorithm with that in mind.
I haven't tried to get stability control working on our car, I think if we added a steering angle sensor and sent the right CAN messages to lie about the engine controller being present it would work, though.
