MountainMeet 2026: September 2-7, the Labor Day Edition
Test run. Coming to a Mountain Meet near you
If you wanna do this, the onus is on you. I gleefully await your trials and tribulations with the "oven" there.
I’m sure there’s a wagon we can set fire to if the lodge oven doesn’t get the pizzas hot. (too soon?)
Or just use the fireplace.. (TOO SOON??)
I'll prob be there Thurs mid-day after a morning start in TN and a back-n-forth on the Dragon on the way to the Lodge. Driving the Miata.
My wife decided to not come, she had a rough trip, diet wise, in Colorado/Utah. It's that damn Alpha-Gal syndrome. It proved harder than expected to make that work on a road trip, she wants to get everything back settled with a more controlled food environment at home vs setting off on another road trip a week and a half after getting home.
Of course. Can you tell me more? Will it do anything over 400F? And is that potentially putting the lodge at risk....if I tried475F?
It’s struggled to maintain 375 in years past but you’re welcome to give it a shot, hell, we can shove a propane burner in there to improve the chooch.
Anyone still using a 215mm/8.5" clutch and want some free used "performance" stuff? I have this sitting around, it's free, just say you want it and I'll bring it to MtnMeet. It's all M46/M47 spline discs. The new pressure plate is a Ford 4cyl application, I doubt it lines up to a stock Volvo flywheel, I only have it because I needed a cheap T5-splined disc for our old lemons car and the whole kit was only $60.
Again, no T5 splined discs here. Volvo spline.
Clutchnet (?) on the top is the 'hybrid' one with the stock-looking organic side facing down.
Wrapped up pressure plate is new, ford 4cyl, as mentioned.
middle disc is Spec stg3 (plus?), I'm pretty sure that came from Sam.
Bottom PP & disc, I believe are both from Paul Schuh's '84 245 Turbo, his first performance clutch.
Again, this is for the flat flywheel. Not something you'd use with a dished flywheel from '87+ n/a.
You must take it all.
Price is free.
18x8.5 Borbet Type A, 5x108mm, 63.5mm center bore, ET18, comes with flat caps. Can deliver to MtnMeet if notified by tomorrow ~10pm.
