940T Wagon 1993 & 1994
- May 13, 2026
About 10 months ago driving my 1994 Volvo 940 Turbo wagon (that I have owned since new) overheated when I pulled off the highway.
The car slowed on a local road engine stopped running. I opend the hood steam was comming from radiator which was 31 years old original radiator. The electric cooling fan did not come on and I could hear the cylinder head gasket break and engine started rattling and shaking as coolant got into the engine. I think the car got low on coolant due to leaking radiator and the cooling fan ground or relay or fan motor was bad.
Also thoughts re putting a Swedish do88 radiator in that for a manual trans only...what kind of seperate radiator do I install and location to cool the trans fluid?
The engine prior to this always ran strong with no problems and original turbo. I am wondering if I can pull the intake/exaust manifolds/head off..check the block and head are not warped, look at condition of cylinder walls then replace all seals, timing belt and tensioner, water pump, get new radiator and hoses, have just the cylynder head rebuilt but NOT remove engine or rebuild rods, pistons?
Would also replace coolant pump, coolant fan, relay and ground.
Is this a good idea, just a head rebuild saving full rebuild for the future or a foolish idea?
What is keeping me from full rebuild is I dont have an engine hoist, or engine stand and ability to pull the engiine and the additional cost.
