Wheel_Wizard
- Oct 3, 2024
- Germany, Lower Saxony
Hello Guys,
I’m planning to do a NA to Turbo engine swap. I’ve just bought a fully functional Volvo 740 Turbo with rear-end fire damage. The engine runs fine and was overhauled before the fire (less than 12,500 miles).
Now, I have a question about the electronics: What exactly do I need to swap the engine into any naturally aspirated (NA) car? I read somewhere that the wiring harness is the same for both Turbo and NA models, and you only need to change the control units. Is that true? It doesn’t sound right to me.
The car also has AC, which I’d like to reuse. Do I need parts of the wiring harness or the entire thing? Or can i just remove the hole thing and bolt it right back when i swap the engine.
Another question: Will I need to modify the chassis, since the air filter is located in a different spot, or are the mounting points already there in NA models?
Is there also a difference in the suspension or brakes between the Turbo and NA models? Because to get TÜV in Germany, everything has to be the same or original, including the brakes, suspension, exhaust, and gearbox.
So if I want to drive the swapped Turbo legally, I need all the important parts that the Turbo versions had back then, including the brakes, etc.
Feel free to ask if you have any questions. I hope this is understandable, as my English isn't perfect since I’m from Germany.
Volvo 740 Turbo 2,3 Liter
165HP from 1990
Has the ECU already been tuned because of the BSR?
165HP from 1990
