Need to figure out the easiest way to change the final drive in my 242GT. Just finished an engine swap with a BMW M54B25 mated to a ZF 5 speed which has a 1:1 5th gear ratio. This doesn’t jive well with the 3.91:1 final drive in my 1030 axle. From the research I’ve done, the tallest axle assembly that would simply bolt-in would have a 3.31:1 final drive, which would be a big improvement, but sourcing a complete axle assembly that isn’t rusted to crap, in the state where the car is (SD), will be next to impossible. As an easier, cheaper alternative, is it possible to just buy a standard rotation gear set for a Dana 30 and install that? This R&P from Yukon with its 3.08:1 ratio would be almost a perfect match to what BMW put behind this ZF 5 speed.
