Need help tackling this no start again
Wesdunns70t5m
Fort Smith Arkansas
The car in question is my 1991 740 turbo lh2.4. Ok I recently changed my rear end assembly, and also deleted the under car fuel pump at the same time. I have an upgraded wall to 255lph in tank pump with its own harness and relay, so it ignores all Volvo logic. Upon completing the above work, the car started and idled for like 15 minutes without issue. Shut it off, showered, and no start since then. It will crank, and every once in a while the tach will jump once when I begin cranking. Other times it won't even do the single tach jump
I started with some easy parts I had spares of before doing any diag. CPS and Coil were replaced with spare used parts. I ohmed out my original and replacement CPS and they both tested good. I than checked at the EZK connector and had the same ohm readings, so those wires seem to be good
I ensured my coil was receiving 12v with the key on position 2. Also pulled the wire from the distributor cap, and used a spark plug to check for spark. I did have continuous spark, but orange and weak
Finally I checked pin 20 on the ezk connector to ground and had a funky reading. I cut the wire from pin 20, and ran a new wire from it to the intake manifold.
Once I ran the new ground wire I pretty consistently have the single tach jump on initial cranking but still no start.
Any help on where to check next would be greatly appreciated. This problem is extremely similar to the one I had with a 1990 760 wagon several years back. That issue never got resolved. I am hoping this one can be
Edit to add resolution!
My main problem ended up being the ignition switch. In the run position everything was good, but in the start position the run contacts showed their age and just wasn't supplying enough power to everything
I would start by ruling things out - are you getting fuel/injector pulse while cranking? Is the fuel pressure adequate? What's going on with the poor spark?
I may have actually figured this out last night. If not completely fixed it, at least moving in the right direction.
All my testing/part swapping was pointing in the direction of the ignition amplifier (the little piece bolted to the inner fender just above the battery)
I was surprised to find one of the mounting screws can't be tightened up, the other screw was fine. The hole is slightly stripped out. You can feel the screw start to tighten, but loosens back up when it's about to actually start clamping. Id went ahead and tightened it carefully to the tightest it would go without popping loose again, and had a consistent tach jump now. Also the car may have burped once like it was going to start, but at this point my battery is in the 10-11v range so it wouldn't start up. I just have to attach some jumper cables and give it a try.
Whether the car starts or not, I will end up drilling out the stripped hole so I can add a rivnut to that same spot and be able to bolt it down with confidence. I know the easier option would be to just rotate the amplifier, and just run the stock mounting screw through a new hole. With how old these cars are, I don't want to introduce new stress on the wiring, which may not be much, but I feel like would definitely be present by adjusting the mounting point(s).
I hadn't even been focusing so much on the fuel side of things. I suppose it's possible I could have ruptured the diaphragm in the fuel regulator and could be having fuel washing the oil off the cylinder walls. I've had that issue on other cars, and just don't hear the lost compression while cranking that I've always associated with washdown. Between the very poor spark being produced and lack of tach movement while cranking, I've been focusing on the ignition side.
In my research on this issue I have learned of a new troublespot with the ezk wiring side of things. I've heard it mentioned before that where the ground lugs attach to the intake manifold, that down the harness is a crimp that likes give issues in these cars. Apparently, there is the same style crimp in the wiring harness inside the car, just before leaving thru the firewall into the engine bay. With my meter tests I was doing, it reinforced what I had heard. The brown lugs were ohming out fine, but pin 20 at the EZK plug was not showing a reading to ground. This is why I just cut the harness at the connector, and ran a new wire from there to the intake manifold ground location. I left the original wires on the manifold in place, and will reattach the cut part of harness onto my newly ran ground wire
The powerstage doesn't ground to the chassis through the mounting screws. Since you found a bad ground on pin 20 of the EZK, I'd check that the pin 2 ground on the ignition amplifier (aka powerstage) is good. Maybe it's partially shared with the original / bad EZK ground wiring? While you're at it, check the pin 4 +12v power on the ignition amp, and on the coil +/15 tab.
The coil showed battery voltage with key on posII. A few volts lower while cranking which from my understanding is acceptable. This was done with a weaker battery btw. I will definitely have to check the pins to the power stage
Unplugged the power stage and verified battery voltage on pin 4 with key in posII. Verified pin 2 to ground was good. Plugged it in, hooked up jumper cables, and no tach again. Unhooked jumper cables, tach was back bouncing but still no start
I went ahead and tried running the negative side of another set of jumpers from battery negative to engine ground that didn't make a difference. Sigh, I'm coming to my wits end here
Any change with the spark strength? Are the injectors pulsing normally? If it's getting fuel but won't start you'll be able to smell it in the exhaust
Get a can of starter fluid and spray it into one of the vacuum lines going to the intake manifold. Try and start the car. Does it start?
If yes, you have a fuel problem.
If no, you have an ignition problem.
Didn’t run before you swapped to the single pump?
Well the plot continues to thicken. Haven't made it to the store yet for a 12v test light or starting fluid. However my battery is toast. Shows 12v resting but drops to 4-6v while cranking. Still a weak orange spark with jumper cables installed and showing 11.5v cranking. No tach movement with jumpers installed. That's kind of the part throwing me. My coil is sparking even with no tach movement...
No start with the starting fluid. Though when trying the tach bounced a single time
Also swapped CPS sensors back to the original. With the one id swapped in I was only seeing .4-.6v AC volts while cranking (I read it should be .7-1.0 V). Still no start with starting fluid, but just as soon as my battery was running low again and I could hear the car cranking slower, tach movement returned.
I'm wondering at this point if it couldn't be the ignition switch itself? I don't think it quite fits the bill, but I feel like I've checked/changed everything I can think of
I think you need to take a step back to verifying the basics. You mentioned no starting with starting fluid, so you probably don't have a fuel delivery issue. The next thing is spark. You mentioned you have weak spark. Have you tested individual components down the line to see where the failure is occurring?
Yes, and everything seems to be testing good. I have a weak spark grounding the coil to distributor lead while cranking. A constant orange spark. Coil, power stage, and ezk we're all receiving 12v with key on pos2. Intermittent tach jumping. CPS wires verified at ezk plug. Engine bay harness verified. Fixed ezk ground issue by adding another wire from the terminal to the intake manifold.
On top of that I've fired the spare parts stash at it
