90volvo
- May 27, 2017
- Eldorado Springs Mo.
Kind of a weird deal. 1990 volvo 240, Turbo 2.3, Microsquirt with Wasted Spark w/VW Jetta coil Bosch 032905106
I converted from my distributor setup to wasted spark about 2 months ago Im using Bosch 032905106 it has the internal igniter. I changed couple setting in tunerstudio like MS instructions say to do. Car ran great, idle great and started great. Well one moring went out to start car, was hard to start and was missing a little. I drove it to work and home with no problem. Figured was time change to spark plugs so no biggy.
Well next day, would not start, I had another coil I was using for back up. Threw it on real quick and car fired right up and ran great. Went to work and back, no problem. Then next morning, no start. So today, I had time to mess with it. Checked for spark, pulled a plug and verified no spark. So I pulled the coil harness plug out and checked for rpm while cranking and have nothing. I checked the CPS plug and all looked good. Im assuming with no rpm during cranking that it would be bad CPS? Is that correct or Im I missing something here.
